Old 03-30-2015, 12:42 PM
carbuff's Avatar
carbuff carbuff is offline
Here is my solution:
I tapped the holes and used 1/8" NPT to -4AN adapters at each port, then 90* hose ends for push lock style hose. The hard part to find was the -4AN cross on the left side (front of the engine), but I Googled and found it at an aircraft supply store. The front attaches to the water pump.
It's quite a list of fittings, and it all adds up in cost quickly when you are putting it together.
I've read different stories on whether this is an appropriate way to go about it, but as best I can tell it seems to be working. It's one of those things that I'll probably never know for sure unless I have a problem.
Old 04-01-2015, 11:11 AM
sjaroslo sjaroslo is offline
Wegner sells these, set of 4 for $27.88. http://s41657.storefront-solutions.c...l.aspx?ID=3289
Old 04-01-2015, 02:14 PM
mitch_04 mitch_04 is offline
Is this what you are looking for? It's off my LQ4, I don't believe I'll be using it, would need to be cleaned up obviously...
Old 04-01-2015, 02:39 PM
Che70velle's Avatar
Winner winner, chicken dinner!
Thanks Dad!!
Old 04-01-2015, 03:42 PM
samckitt's Avatar
samckitt samckitt is offline
Yes that's the one. PM me a price if you want to sell it. With shipping. I'm in carrollton VA 23314.
Scot
86 Monte SS
LS2/T56 Magnum
Old 04-03-2015, 08:29 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
try turnkey engines thats where i got mine but its only a 2 port not 4.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 05-10-2015, 07:04 PM
tobenk tobenk is offline
I got mine from Wegner also.
