Old 03-26-2015, 09:25 PM
Originally Posted by kevin_l View Post
I have this kit coming as well, and was planning on running both positive and negative the full length. Being a uni body car I figured it was best, I am very weak in electrical knowledge, can anyone chime in on the matter. Is this normal practice or a waste of cable. Like cywlie said the kit comes with enough cable to do this. So no extra money is spent. Interested to hear what everyone else does too. thanks
Check out madelectical.com it has a lot of great wiring tips and electrical products for your build. Good luck
Old 03-26-2015, 10:39 PM
randy randy is offline
Im going to buy the DSE kit and run both wires to the firewall, I will also ground the battery in the back of the car too, run a cable from the front subframe to firewall, cable from radiator to subframe, engine to subframe, and that should be good
Old 03-27-2015, 12:50 AM
Originally Posted by barrrf View Post
A shorter ground is a happy ground. It is best practice to make the grounds as short as you can.
Yep and multiple points too.
Could have cut that ground wire up and made a bunch of 1" gound straps. Don't forget the trans cross member to transmission too.
Old 04-01-2015, 03:25 PM
kevin_l's Avatar
kevin_l kevin_l is offline
Just received my PSI harness and reading through the manual it states, a ground directly from the battery to the motor is required. And Motor to chassis. So if I just drop a short ground from the battery to the chassis, I won't have a way to supply a second ground from battery to block. I haven't started running wire in my car yet so I would like to do this right the first time. And like I said before I have enough ground cable to run the length of the car supplied with the dse kit.
Old 04-11-2015, 05:26 PM
gray86hatch gray86hatch is offline
I always run a ground from the battery to the block, Battery to frame and block to frame.
Ground the engine in at least 3 spots.
Never had issues.
Tim
86 mustang
454 lsx FTI ls3 mast 4500 9.24 144 pump gas dragradials
79 z28 29k org miles. DSE suspension Bonspeed GTB
The Following User Says Thank You to gray86hatch For This Useful Post:
svtredsnake (06-30-2020)
  #16
Old 04-12-2015, 01:47 AM
frankv11's Avatar
frankv11 frankv11 is offline
This will answer all you questions and more
http://www.w8ji.com/battery_wiring.htm
Old 04-12-2015, 09:32 AM
SlowProgress's Avatar
There are so many ways to do this. I ran fine stranded welding cable from the trunk where I had the battery and shutoff, just one cable and then grounded to the body to save running more than one cable the whole length of the car. I like the welding cable because it has good insulation and bends very easily. I ran the cable and drilled a hole as shown in the sketch
and here is the actual hole but the car is apart now
The cable runs through a big fat grommet into, and out of the rocker and there is a p-clamp to support the cable just before the grommet at both ends. I also split some plastic irrigation hose and covered the cable inside the rocker to prevent chaffing where it is hidden. Here is where it comes out the front of the rocker.
I like this because the cable takes an easy turn and is right there where the starter is (at least with the big block).
I plan to add a large fuse in the trunk this time in addition to the shutoff.
As Greg mentioned above any movement could potentially cause wear, so make sure nothing can move and avoid running the cables over sharp corners. If a large cable shorts out make sure it is protected by a fuse that will blow before too much damage is done.
