Old 05-13-2015, 01:10 PM
Ketzer's Avatar
Ketzer Ketzer is offline
We have the 40 mm taller intercooler bricks and spacers in from C&R. We hope to dyno is in a couple weeks.
I had to purchase 4 sets to cover the tooling so if someone needs/wants a engine set IM me.
Mark
Hmmm, I wonder if those would fit my CTS-V....?
Old 05-13-2015, 01:45 PM
Stielow's Avatar
Stielow Stielow is offline
A CTS-V lid and a ZR-1 blower lid have the same bolt pattern.
So will it bolt up... Yes. I would need to look at the sealing inside on the bottom of the bricks to the blower.
Mark
Old 05-13-2015, 02:12 PM
GRob GRob is offline
Mark I'd be interested as well for an LSA.
Old 05-13-2015, 02:32 PM
Stielow's Avatar
I think there would be a better cost efficient solution for a LSA. By the time you buy an LS9 blower lid and the C&R parts it would be very spendy.
I'll look at a LSA system to see if a better intercooler could be made.
Mark
Old 05-13-2015, 04:11 PM
It won't fit, the LSA has a single brick and it sits right in the middle over the opening in the supercharger. I already asked if C&R was going to do something similar for the LSA and they told me not right now but you never know. They would probably sell a ton of them if they did.
Old 05-13-2015, 09:05 PM
CarlC CarlC is offline
We do have a RetroWorx kit for single modules. For duals it's usually best to make your own mounting plate.
http://vaporworx.com
Mark, are you using the full fuel system during the dyno runs for validation?
http:www.vaporworx.com
Old 05-14-2015, 12:52 AM
Bmf5150 Bmf5150 is offline
Looks great
Old 05-14-2015, 01:43 AM
BigRedCamaro BigRedCamaro is offline
This is a great thread. Amazing work on an already awesome '69. A lot of great ideas here. Keep it up Mark.
BigRedCamaro.com
The Original Outlaw Racer
The Fastest '69 Camaro On Earth - Current Top Speed 238.1 MPH
Old 05-14-2015, 05:18 AM
Stielow's Avatar
Carl
That is the plan. We will use the tank in the dyno cell and start with 100% gasoline then go to E85 then look at blends (E50, E25...) To make sure the flex fuel sensor is working correctly.
It is a bit more work to run the system in the cell but then you can control everything.
We will also A/B test the bigger intercooler bricks.
Still a lot of little details to work out.
Mark
On a side note we fired up the hoist last night. No more rolling around on the shop floor.
Old 05-14-2015, 08:10 AM
You'll never go back to jack stands and creepers. I used to refuse to go to my buddies houses to help them --- they HAD to bring the car to me so we could use my lift.
