07-13-2015, 06:10 AM
Originally Posted by classiccamaro
Got my 69 up and running....I have 4 wheel disc brakes, Wilwood 6 piston in front and 4 piston in the rear. My question / concern is this, Wilwood says the pads need to be bedded. Is it normal for the brakes to sound like you ran over a Bobcat? The car has not been on the road yet, but moving it around the shop has me bit worried.....the brakes makes a terrible screeching/howl when applied. Is this normal until the pads have been bedded? Need advice. Thanks
NO they should not sound like that! EVER....
Get it up in the air so you can see the back side of the rotors - my guess is you have a bolt in a caliper that is up against the rotor! You should see it quickly because it's probably already left a witness mark.
