Old 04-28-2015, 12:37 PM
DavidBoren DavidBoren is offline
Why a 4-link instead of an offset 3-link? Just wondering.
And if you can package it, a watt's link with a chassis mounted bell-crank would be really cool to see. Put the bell-crank on a socket-adjustment riser with access to socket through the floor of the trunk.
Old 04-30-2015, 10:38 AM
dukeboy_318 dukeboy_318 is offline
I chose the 4 link, parallel, for a couple reasons, First, this is a street/strip/PT car and I need to retain the rear seat, a 3 link wouldnt let me do that, not without a short 3rd link bar, too short for its own good. Second, this car will not only see the strip and straight line, but the torque of the 440 makes a 3 link not strong enough for the drag strip, at least in my opinion. Plus the parallel will allow full adjustability while still helping to plant the rear tires.
Old 04-30-2015, 11:06 AM
All good points. I was just curious. Thanks for answering my questions, though. I figured you had a legitimate reason.
Old 04-30-2015, 12:03 PM
No problem, I am open to suggestions. especially on how to make this Watt's bar work. That's where I'm conflicted.
Old 05-06-2015, 05:51 AM
Working on mounting in the new(used) set of buckets. Not being factory mopar seats, I'm having to cut the bench riser out of the floor to get them to mount flat, other than that they are fitting pretty nice. In progress pic..
Old 08-10-2015, 05:58 AM
Been a long while since an update. A lot has happen. Car is completely stripped, now up on a body cart. Hoping to blast it in a couple weeks.
But I did pick up a few new toys
Out with the old.....
In with the new:
Old 08-10-2015, 07:35 AM
Old 04-24-2016, 04:26 AM
The old owner's "fix"
Old 04-24-2016, 08:30 AM
no go nova's Avatar
no go nova no go nova is offline
Looking good and there are some guys mounting the watts link under the axle for packaging?
Old 07-07-2016, 09:03 AM
thought i'd post some updates over here. After months of thoughts, I came to the conclusion I lacked the fabrication skills I needed to trust my life on my suspension, so I got with Carl Gerst at Gerst Suspensions and told him what I wanted and he went to work. This is what we have together thus far. It's still in progress and this is just the mock up version to make sure everything fits and works. It's being tested as we speak too.
4 link parallel with Watts link with sway bar
