08-11-2015, 07:42 PM
LS Transplant EFI help
On the fence choosing a EFI transplant kit for my 67 Corvette, installing a 2008 LS7 with West Coast Cylinder's stage II heads, comp cam Dur @ .050 281 289 112 Lobe Sep & 650 lift, LSX FAST intake and 1023 TB. Close ratio magnum T56. Choosing between FAST EZ-EFI, Terminator LS MPFI Kit or flashing the original computer. Would like suggestion or experience with EFI transplant systems. Building mainly a street car and occasionally auto crossing.
08-11-2015, 11:37 PM
If it were me, I'd use the factory computer.
There are lots of tuners out there that are very experienced and very good with the factory ECUs. Finding a tuner for an aftermarket system is quite another thing.
08-12-2015, 03:41 AM
agreed
Agree with above, I used factory computer on supercharged LS7 and the BEST tuner in my area.
Cheers
Steve
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
08-12-2015, 05:50 AM
Thanks for the replies.
08-12-2015, 08:31 AM
Are you going to want to make changes to the tune yourself in the future? What do your local tuners use/prefer? Stock ECU is great, but not as user friendly as some of the aftermarket options. And if you are going to rely on someone else making every change to your calibration, you might as well use what they are most comfortable with.
08-12-2015, 09:57 AM
Stock puter PSI Harness
08-13-2015, 04:09 PM
Try looking at this;
http://aemelectronics.com/products/p...-efi-solutions
http://www.aemelectronics.com/produc.../infinity-6-8h
Wicked fast processor and lots of features. Competitively priced with that FAST and Holley but does way more. This 1 box controls everything with the harness listed, and no added spark box like the FAST. Plus trans control to be added this fall.
Good stuff.
Mark
Engine builder and tuner.
08-14-2015, 11:12 AM
I had a Fast XFI system in my old 67' Nova with an LS6. I'm sure it's great for experienced tuners, but the shop who did my car could never get it running right... Too complex. I'd opt for a factory computer in the future.
1964 Chevelle Malibu SS
08-15-2015, 04:56 AM
Thats a huge cam for the street, even for an LS7. I would reconsider using it, or at least talking to someone who custom grinds cams. Nothing worse that having to tear into a nice clean install to make changes. I also prefer the stock ecm/injection system for your intended use. Scott
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
08-17-2015, 09:25 AM
I am in the same spot, and here's my opinion fwiw.. Why pay for a tuner/dyno tune, and pay again of you make additional changes, gears, cams, heads, etc... Plus it seems as if there are a lot of tuners these days. Yeah 2500 is a lot of coin to drop on a controller (if it's got the trans control) but 400-600 for dyno tunes, plus 100-200 for re-tunes, or if the orig tuner doesn't do it right, then your back at square 1
