Old 08-25-2015, 05:37 PM
Grnova's Avatar
Grnova Grnova is offline
Default Power steering pump problems
i have not had the car running long and it seems my power steering pump is making all kinds of noise. Any have a good recommendation for a quality type 2 GM style pump? I will be road racing and auto crossing the car. Has a Dse front clip and a ls2 with a kb supercharger.
Thx
Tim
Old 08-25-2015, 07:35 PM
70 tt rustang's Avatar
70 tt rustang 70 tt rustang is offline
Dse sells them i believe
Old 08-25-2015, 08:24 PM
Musclerodz's Avatar
usually a sign of air in the system. Do you have hydroboost on it?
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-26-2015, 03:27 AM
Grnova's Avatar
Hey Mike, no I do not have hydro boost. I tought o had all the air out it sounds ok when I start it for about 5 min the after a drive around it sounds louder than the Kb. I turned it from lock to lock slowly wit the cap off and still nothing.
Tim
Old 08-26-2015, 12:17 PM
Just a stab, but what pump do you have? Does the pressure match the rack....also double check your lines for proper routing.
Old 08-26-2015, 02:48 PM
Grnova's Avatar
Vince, I am running a Sweet Mfg. pump
Open flow 3.0 gpm
Flow @ 600 psi 3.2 gpm
Max flow is 1030psi
Good point if it matches the DSE rack I do not know?
Tim
Old 08-26-2015, 02:49 PM
dontlifttoshift's Avatar
dontlifttoshift dontlifttoshift is online now
.....also, which reservoir do you have and what fluid did you use.
-10 from reservoir to pump, right? Make sure that hose is vacuum rated as well.
Donny
Grnova's Avatar
Oh yea I went through the line thing already.�� they are correct!
Tim
Old 08-26-2015, 02:52 PM
Grnova's Avatar
Donny I have a Billet Specialities resevoir...and no -6 is run for every PS line.
Tim
Old 08-26-2015, 02:59 PM
Grnova's Avatar
2B3-A5FFB6A31BE6.png_zpsiipe28mo.jpeg.html][/URL]
Tim
