Old 09-02-2015, 07:02 AM
Swain's Avatar
Swain Swain is offline
The rockers and push rods aren't bent the engine was never turned over with water in it
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 09-02-2015, 07:54 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Originally Posted by Swain View Post
Here is one of the three that are loose.
Would cha look at that !!!
The rocker is not fulled seated in the rocker stand or the rocker stand is damaged.
Name:  LS3 Rocker Stand.jpg
Old 09-02-2015, 08:34 AM
carbuff's Avatar
carbuff carbuff is offline
I'm not sure how that could possibly happen if the bolt is still tight. The stand is what keeps everything in alignment...
If you decide you are going to replace the valve train, I have the components I just removed from mine that I plan to list for sale soon. Lifters, trays, LS3 rockers with trunion upgrades. If you're interested, drop me a PM.
Old 09-02-2015, 10:17 AM
Swain's Avatar
Found the problem..........
The threads had crap in them. Cleaned them out everything is back to normal.
That was some good news
Jason Swain
Old 09-02-2015, 12:33 PM
Swain's Avatar
PM Sent..
Jason Swain
Old 09-02-2015, 03:23 PM
Vega$69's Avatar
Glad it was an easy fix. The LS motors are pretty simple when you get right down to it.
Just curious. Why and by whom were the rockers taken off in the first place?
I would pull them all. Clean all treads and replace and re torque
I also use a spray valve train lube made by comp to spray the rockers, springs and ever thing before I pop the rocker covers back on
Old 09-02-2015, 03:36 PM
Swain's Avatar
[QUOTE=Vega$69;615601]Glad it was an easy fix. The LS motors are pretty simple when you get right down to it.
I also use a spray valve train lube made by comp to spray the rockers, springs and ever thing before I pop the rocker covers back on[/QUO
Cleaned up everything and adjusted them all.
Jason Swain
