Old 10-05-2015, 07:13 PM
rjardy rjardy is offline
The car runs a little hot. I get around 200-210 sitting in traffic. Ive wired up an electric fan and that really knocked out the cooling issue. But knowing that I have an issue I wanted to do something more to keep the air directed in to the radiator. The rad is an ebay special that is really just a wide 2 core. I want to see if I can get the cooling totally dialed without having the added expense of a new radiator. I came up with some little baffles (i guess thats what they are) that run between the core support and the grill. I've seen a few people run/make these and as an added bonus, it cleans up the appearance a bit under hood.
Started with cardboard
I do not have a brake so the bending was done with a bench vise and rubber mallet.
I just noticed a small dent in the panel. ah-well...
Ill post the finished product with both sides soon.
Rob
Old 10-05-2015, 08:42 PM
DBasher's Avatar
DBasher DBasher is offline
The close out panel is looking great Rob, nice work! I couldn't see the video of the rear suspension but saw you mentioned upgrading the rear CO's. I've got some double adjustable VariShocks I could send you if they'd work. They need to be rebuilt....I don't remember what they told me for rebuilding but it was waaay cheaper then new ones. If they'll work and you're interested, you can have em.
Btw, your tach is crooked
Old 10-05-2015, 08:48 PM
Thanks for the kind words. As for the CO's that sounds perfect! I really appreciate that. Where are you located?
Rob
Old 10-05-2015, 08:49 PM
haha!
Old 10-05-2015, 08:51 PM
DBasher's Avatar
I'm just east of Seattle. I'll go out and get some details/measurements and let you know what they look like. Have you got a picture of the rear set up?
Old 10-05-2015, 09:03 PM
DBasher's Avatar
10-1/2" C-C compressed
14-1/2" C-C extended
The second picture is one of the fronts, looks the same to me other then the top mount which can be changed.
Old 10-05-2015, 09:04 PM
No pictures at the moment. It is the TCI 4 link for the Falcons. Those look like they'll work great. Let me take some measurements.
Old 10-05-2015, 09:05 PM
DBasher's Avatar
Second picture showing one of the fronts.
Old 10-05-2015, 09:07 PM
12.5 center to center at ride height. Those should work great.
Old 10-05-2015, 09:20 PM
DBasher's Avatar
I'll send you a PM, you want the fronts as well? Haha!
