Originally Posted by Nativefx
With their engine mounts and crossmember I'm assuming the pre-fabbed tunnel would work. Did you have any issues with getting the carpet to fit due to the shape of the tunnel cover? I have a one piece carpet kit to install once i'm ready. I've had someone tell me they had to send the x member back because it didn't provide the correct angle for his Magnum. My installation does include a T56 Magnum so i'm almost certain a tunnel mod is necessary.
The tunnel box is fine, but would use something different if your not running a console. Its not designed to be pretty. They make 2 different crossmember heights so they may have sent the wrong one.
