Originally Posted by slownova
do you have any personal experence with any of those? i want something that gives me a good ride, great handling, and great steering. im kinda leaning twords the RRS stuff becouse it seems simple and a real nice kit and i don't have to cut to much on the car.
- All except RRS.
My current car ('67 coupe) and combo has the Ron Morris front. I upped for DA coilovers and 450# springs. His kit calls for lengthening/shortenning the LCA for camber adjustments. I opted to keep the arms the same length, and made eccentric eliminators offset to dial in camber. Also I did not drop the upper arm as far as called for, as this gets into too high of a Front Roll Center (for my liking) ... 1.25" is enough for me.
I am using the TCP power rack, and KRC power steering pump. I like this of all of the rack kits out there ... although it is definitely the priciest.
I have used Global West in stuff in the past ... and liked it.
I have used Mustangs Plus Grab-a-Track stuff in the back of my car with good results.
My front 1.25" hollow sta-bar came from cobra automotive.
I prefer the three coil over kits to the strut conversion kits (RRS and Fatman's), as in my mind a double a-arm set up is a step up in performance vs struts. However, for a driver, and where price is a concern the strut setups are a great way to go.
