Old 03-19-2016, 01:15 PM
John510's Avatar
John510 John510 is offline
Default Rolled rear quarter panels
Does anyone have a detailed pic of what a correctly rolled/trimmed rear quarter panel should look like for a 68 camaro?
John
[SIGPIC][/SIGPIC]
Old 03-19-2016, 05:03 PM
All you need is about a finger width between your outer fender and tire. It sounds like you rear end is to wide or you need to remove a spacer between the axle flange and wheel. How much room do you have on the inside between your tire and wheel tub? You need more space on that side to avoid a rub over transitions.
Old 03-20-2016, 07:43 AM
DOOM's Avatar
DOOM DOOM is offline
Originally Posted by John510 View Post
Does anyone have a detailed pic of what a correctly rolled/trimmed rear quarter panel should look like for a 68 camaro? I got my car back and within 10 miles it caught the lip on the quarter panel and bent it. I was driving 20 mph on a straight and smooth residential street. Im very pissed about this!
John
John take that SOB back to your builder!!! How the hell does this happen that should be there problem!
Mario
USCOLLISION
Old 03-20-2016, 09:14 AM
clill's Avatar
clill clill is offline
I would be worried about the rear end being loose somehow. How the 1/4 lip is trimmed and rolled should not matter if you have proper clearance and the suspension is correctly installed. Show us how much clearance you have.
Old 03-20-2016, 09:31 AM
glassman's Avatar
glassman glassman is offline
Very good point, I'd seriously look into this.
John, pm me as i've got several local contacts for the different aspects of this.
Charile, nice avatar change...
Mike
Old 03-20-2016, 01:38 PM
Richio1's Avatar
Richio1 Richio1 is offline
From one of the DSE builds
Jeff
Lateral-g Feature - https://lateral-g.net/forums/showthread.php4?t=44186
Build thread - https://lateral-g.net/forums/show...ght=brownstone
Special thanks to Matt's Classic Bowties along with
Old 03-20-2016, 09:49 PM
I agree, take it to a capable shop that can set it up properly. And look the rest of the car over carefully.
Old 03-21-2016, 04:40 PM
DOOM's Avatar
OMG!! John WTF!!! That's ridiculous!! That's a ''Race setup!?!?!?!?!? Ya I can see why you wouldn't take it back!!!
Mario
USCOLLISION
Old 03-21-2016, 09:14 PM
randy randy is offline
yea so my heart dropped seeing that pic. The tire doesn't look too bad. You could also put the tire on the other rim since most likely its a directional tire. rim offset looks wrong like you mentioned.
Now to find out what is cheaper, Floater rear end so you can shorten the rear end some more, See if you have enough on the hat of the rim to shave down ( doubt it ) rebarrell the rims.
