Old 08-03-2016, 12:33 PM
lsuguy's Avatar
lsuguy lsuguy is offline
Nice progress Wayne!
Old 08-03-2016, 09:41 PM
Thanks Derek!
I got a little more done today ground the welds down on the frame and preped it for paint. I used self etching primer and will spray the Black tomorrow.
First coat
I ended up putting 4 coats, Ill sand it and spray the rest tomorrow.
Then move on!!
The Following User Says Thank You to waynieZ For This Useful Post:
kwhizz (01-16-2021)
  #1033
Old 08-04-2016, 07:16 PM
Today we got the frame notch sprayed black and mounted the A/C bracket up for good.
We had to take one frame mount bolt for the notch so I drilled and tapped the frame for another one. I made a 3-1/6" thich washer (plate) to cover both bolt holes to help hold the frame mount istead of two washers with one side on each ground because they are so close together.
Old 08-05-2016, 07:00 AM
slenning's Avatar
slenning slenning is offline
Nice work on the frame notch Wayne!! One step closer to getting this bad boy fired up!!!! Gonna be a great car
Steve
70 Camaro - in process https://lateral-g.net/forums/showthread.php4?t=50636
69 Camaro LS7/T56 https://lateral-g.net/members/lenning/
69 Camaro SS396/350hp
64 Chevelle - patiently waiting
2014 Z28 Ashen Gray
2010 Camaro 2SS/RS Black w/White stripes (wife's car)
2015 SS (the 4 door one) Wife's other car
Old 08-05-2016, 09:12 AM
Sonar Chief's Avatar
Cool
Very well done sir! Seems like the little stuff seems to take the longest don't it?
Keep at it!
Old 08-07-2016, 09:07 PM
Thanks guys we're plugging away.
Old 08-10-2016, 09:48 PM
Got a little done today, we started to make a top bracket to hold the A/C compressor in the low mount position. We had it together and then the A/C connections for the compressor came in and of course it was going to be tight on one side so apart it came. I bent up another arm and Spacemwn welded it on. I cleanded it up and primed it today and I'll paint it tomorrow.
Here it is in etching primer.
The little notch is to clear a bolt on the compressor.
amazing how such a little thing takes so long to get it right. Thank god we enjoy this stuff!
Old 08-10-2016, 09:54 PM
grendel grendel is offline
The last 5% takes 3x the time of the first 95%.
I am there now on Betrayal.
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
Old 08-10-2016, 09:57 PM
That sure is the truth!
Old 08-11-2016, 07:41 PM
Last night I painted the A/C bracket and today I installed it to see how it looked. Lesson learned, bring you glasses when you need to read a paint can. I picked up two cans of paint. One aluminum and the other metalic satin Nickle. Ah I'll get the aluminum so it will blend in instead of black. Get home spray the bracket, hmm looks pretty good. 3 coats, read the can Nickle ??? But it looks good so maybe somebody was watching over me and helped with the color choice.
Too stinkin hot in there today, 98 with the windows and door open.
