Old 04-02-2016, 04:25 PM
Default Lucky I found this.. Could have locked up the steering
Remember that time you figured out that your nice billett steering arms are hitting the tie Rod ends and locking up the steering ... Gee that as a fun time wasn't it
Old 04-02-2016, 04:27 PM
Jesus thus could have been bad
Old 04-02-2016, 04:29 PM
grendel grendel is offline
Glad you found it now.
We spent a lot of time, cycling steering, suspension, etc. Found things like control arms hitting and locking on coil over springs, sway bars hitting and locking suspension down... I guess "that's hot rodding"
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
Old 04-03-2016, 02:28 PM
Default staying with the theme of "Sketchy things I find"
Since I had to take the entire front suspension off to drill two holes :-)
I figured I would replace the wheel studs with longer ARP studs..
In keeping with the theme of Scary stuff I find.. I think a shorter bolt should have been used on this hub to spindle connection....
Old 04-03-2016, 02:31 PM
Is it longer for your steering arm or something?
Yeah, it's a bit close.
When are we going for that beer?
68 GMC C1500
73 Camaro
Old 04-03-2016, 05:33 PM
Just too close for comfort I cut 1/4 inch off it and it still had more to go...
Let's plan the beer gimme a call or pm
Old 09-05-2016, 05:23 PM
Default Prop valve
So haven't seen anyone do this but I got obsessed with the idea to be able to adjust the brake pressure from the drivers seat
Old 09-05-2016, 05:25 PM
Default Valve
So I picked up the detent type valve ran these neat bulkhead connections with -an to the valve . It's in a good spot to get to it without being in the way
Old 09-24-2016, 06:22 PM
Default More brakeline bending
Had to redo this as it was interfering with the steering column
Old 09-24-2016, 07:17 PM
The lines look good.
