Old 10-25-2006, 06:50 AM
31 SONIC 31 SONIC is offline
Default Mule rear wheel dimensions
or similar cars. I'd imagine it's a 12" wide wheel. Does anyone know what back spacing it is. I want a deep dish but not too deep to where it looks stupid. It looks about centered so I'm thinking it's 12" wide with a 6" b.s. or close to it.
Old 10-25-2006, 07:02 AM
XcYZ's Avatar
XcYZ XcYZ is offline
I can't remember the exact backspacing that was used on the Mule, I know there was 2 sets of wheels and each had a different dimension.
I went 18x12 with 6" of backspacing on mine and I'm happy with it, I'd do it that way again.
My LS7 69 Camaro
Old 10-25-2006, 07:23 AM
Thanks for the reply. I'm looking at 11" wide and am torn between 4" bs or 4-3/4" bs. Guess I'll sleep on it.
Old 10-25-2006, 07:55 AM
tracy's Avatar
tracy tracy is offline
I am doing 18x12 (335/30x18) with 5.5" BS.
Goodies Speed Shop
Old 10-25-2006, 08:22 AM
camcojb camcojb is online now
The current Mule wheels are 18 X 12.5" with a 6.375" or 6.5" b.s., depending on whom you believe.
Obviously your rear end width also figures into this.
Old 10-25-2006, 08:42 AM
Thanks again guys.
I think I've decided on 11" wide and 4.75" of backspace. I think 4" backspace would be too deep. I still have to do the rear end, so I'm not limited to my wheels.
Old 10-25-2006, 10:13 AM
69Camaro's Avatar
69Camaro 69Camaro is offline
a little off topic, but are we talking about deep tubs and backspacing with a stock width rear end.... I'm just starting my 69 Camaro project and still inthe planning stages......
Old 10-25-2006, 10:25 AM
907rs's Avatar
907rs 907rs is offline
The bs measurements mentioned above are for use with a narrowed rear end.
Bill
Old 10-25-2006, 11:03 AM
Yes, these would be measurements for a narrowed rear end and minni tubbed car (71 nova in this case). If a stock width rear was used you would need approx. a 7"-8" backspacing which would make the wheel have a very shallow lip on it. Idealy, if you are getting a new rear end or narrowing your stock one, purchase the wheels you want first, set them under the car where you want them, then measure for your rear end. That is alot easier than trying to find a wheel that will work with your existing rear end.
Old 10-25-2006, 07:15 PM
tracy's Avatar
I am doing 18x12 (335/30x18) with 5.5" BS. This is also what was recommended by DSE.
Goodies Speed Shop
