Closed Thread
Old 11-05-2016, 06:03 PM
jwcarguy jwcarguy is offline
Banned
Default LS3 Intake manifold setup takeoff w/ injectors, rails, etc
Item Location (City/State):Las Vegas, NV 89131
Price: $425 SOLD!!
Description:
I have a low mileage take off (8k) LS3 intake manifold setup
comes complete with:
-intake manifold
-manifold & TB seals
- GM MAP sensor and hold down screw
-GM fuel rail assembly w/ hold down bolts
-GM LS3 / LS7 42# fuel injectors w/ retaining clips
-upper intake manifold beauty cover ( some refinish them for custom look , see carbon fiber pic as example)
fits all LS / Vortec engines with rectangle ports cylinder heads (ie L76, L92, LY6, L99 , etc)
Complete intake manifold assembly as listed above $425 + shipping SOLD!!
I do also have a new LS3 (gold blade) take off DBW throttle body available for a extra cost
pm/call/ text (702)677-4085
Old 11-07-2016, 11:07 PM
tpichevy's Avatar
tpichevy tpichevy is offline
Will this bolt onto a 2009 6.0 Yukon ls2? I'm new to the LS motor so I have lots to learn.
TYRFRYR- Built 92 Chevy truck, pro-touring!
CLASSIC - 1970 camaro working on getting pro-touring!
Old 11-08-2016, 07:29 AM
Banned
It may, depending on which cylinder heads that you have on the engine
This is for rectangle port heads
Look for 3 digit cast # on corner of heads , near valve cover (ie 317, 799, 821, 823, etc. )
They never put a "LS2" in a Yukon, you may have a 6.0L, but not a true LS2
Jeff
Old 11-08-2016, 10:16 PM
tpichevy's Avatar
It's a 6.0 aluminum block with 243 heads .....been told it's the same as a ls2...is that wrong?looking to do a ls swap in my 1970 camaro
Old 11-09-2016, 07:31 AM
Banned
Not necessarily
similar to the L92/ L99 vs LS3 same displacement, but many differences between them
the "243" heads are cathedral port, so the LS3 intake will not work for your engine
Old 11-11-2016, 08:54 AM
Banned
Intake manifold setup & TB are SOLD!!
Closed Thread
