Item Location (City/State): Chicago, IL
Price: $40,000.00
Description: See Below
When I started building this car the goal was to build a car that I could Autocross, Track and still be able to participate on the Power Tour. Since
I completed parts of three Power Tours with the car upgrading each year to try to make it just a little better then the last.  Each part was chosen
with the intent to make this car handle significantly better then stock and stop from very high speeds without concern. When my nephew and I
participated in the 2015 Power Tour with all of the mods you see in the list below (minus the Stainless Works Headers, High Flow Cats and Exhaust
we got 21 mpg which exceed my expectations.
If you want a car that you can get in a drive cross country and still have fun this is the car. It has more than enough HP to get you in trouble quickly
as it has 568hp at the wheels with a mild tune and the small crank pulley so it has plenty more in it. The current set up is mild enough to cruise on
the highway or your local streets.
Unfortunately the time has come to sell my baby as I have way to much going on in my life and my wife said it was okay to buy another car (so I did)
and I a afraid I won't have the time to enjoy this car. So I would love it to go to a good home and get enjoyed by the new owner.
Build thread ((
https://lateral-g.net/forums/show...772#post648772 ))
2010 SLP 575 Bumble Bee Camaro (1 of 12)
10,109 miles
$40,000 or best offer ( I have well over $100,000.00 invested in this car )
Ordered SLP Option Include
  $19,995.00 SLP 575 Supercharger
  $4,495.00 Brembo GT Brake Package Front
  $690.00 Rear Sport Rotor Upgrade
Engine Bay
 SLP Coil Covers (Painted Red)
 Seibon Carbon Fiber Cowl Cover
 Stainless Works High Flow Cats & Chambered Exhaust
 JDP Remote Clutch Slave Cylinder
Wheel & Tire
 MR228 Z28 Style Wheels Gloss Black w/Gorilla Wheel Locks
 Goodyear F1 Tires
Chassis Modifications
 LG Motorsports Subframe Connectors
 LG Motorsports Coil-Over Conversion
 Rear Brembo Red Calipers w/ 1 Piece Rotor
Chassis Bushings
  1.   Pfadt # 1410112 - Pfadt Rear Trailing Arm Bushings
  2.   Pfadt # 1410113 - Front Lower control arm bushings
  3.   GM   #  22845487 1le Toe Rod
  4.   Pfadt # 1410115 - Rear Lower control arm bushing
  5.   Pfadt # 1410116 - Rear upper control arm bushing
  6.   Pfadt # 1410117 - Front Trailing Arm bushings
  7.   Pfadt # 1410101 - Racing Sway Bars w/Pfadt Lower Control Arm brace
  8.   Pfadt # 1410196 - Solid Body Bushings
  9.   BMR  # BK046    - Differential Bushings
Paint & Body
 3M Wrapped front Facia, Hood & Fender Sides
 Seibon Carbon Fiber Hood...Single Stripe (carbon exposed) with Red Stripe
 Seibon Carbon Fiber 1LE Cabron Fiber Front Splitter
 Seibon Carbon Fiber ZL1 Rockers
 Seibon Carbon Fiber ZL1 Rear Diffuser
 Seibon Carbon Fiber Trunk Insert
 Seibon Carbon Rear Spoiler with Aerosports  Wicker Bill
  ZL1 Grille
  ZL1 Fender Extensions
  ZL1 Splash Guards
  Yellow Fog light covers
Interior
 1le Suede Flat Bottom 2014 Steering wheel w/Airbag
 1le / Zl1 Shifter &  Suede Shifter Boot & Handle (Not Installed)
 Black 4 Point Harness &  Harness Bar (Not Installed)
Unfortunately the Stainless Works exhaust was not on when I took this picture.
Front end has a clear bra on it.
