Old 12-20-2016, 04:06 PM
Doug1's Avatar
Doug1 Doug1 is offline
Default Best undercarpet heat insulator
What the consensus on thermal protection for the floor. I have already put Dynamat Extreme on for sound deadening. Now I need to move on to heat insulation since the headers and exhaust are tucked up within 1/2" - 1" of the floor.
Old 12-21-2016, 08:11 AM
Sieg's Avatar
Sieg Sieg is offline
Manufacturers use more shielding products outside the cabin than in. Take a look at the auto product offerings here https://www.heatshieldproducts.com/a...t-shield-guide it may give you some ideas.
Air space and air flow are your friend.
Old 12-21-2016, 09:46 AM
Doug1's Avatar
That's a lot of components. Is there a 60s-70s Camaro or Firebird build on here with the stuff that sticks to the bottom of the car? I'd like to see how it holds up.
Old 12-21-2016, 11:54 AM
jeds jeds is offline
I've heard good things about DEI heat shield.
https://www.designengineering.com/ca...und-insulation
I don't have any first hand experience with it.
Old 12-21-2016, 07:33 PM
DT69Cam DT69Cam is offline
HushMat # 20300. I think it comes in 1/2" thick pieces the ones I'm referring to.
69 Camaro Convertible (LS3/TKO in the works)
Old 12-21-2016, 08:32 PM
dontlifttoshift's Avatar
I have that stuck to the bottom of a customers 69 Camaro for nearly 5 years now.....still there. Have had the trans out a couple of times in it wasn't sagging anywhere.
I use that with DEI UnderCarpet lite and it works pretty well.
Donny
Old 12-21-2016, 09:05 PM
craig510's Avatar
craig510 craig510 is offline
I used a bunch of the DEI heat shield on my fire wall, transmission tunnel and fuel tank. Good stuff. Has held up well for almost 4 years. I used the tape they sell to seal the edges and seam. It looks very OEM and does a good job of keeping the heat out.
Old 12-22-2016, 02:20 AM
booah booah is offline
I've used the DEI product also, have about 1500 kms and no issues, sealed the edges also and was stuck to a newly painted surface underneath.
Old 12-22-2016, 08:56 AM
That does look like a nice product however it installs on the Exterior. I wouldn't want to see that on my firewall. If I used it, I would do the trans tunnel. Kinda out of sight. Just my .02
Old 12-22-2016, 07:56 PM
JKnight JKnight is offline
I used a second skin audio product. Heat wave maybe? Worked like a champ. My right heel used to get hot through my shoe from the collector and it totally cured that. Foil on both sides, jute-like material in the middle.
Yep: http://store.secondskinaudio.com/the...sulation-mats/
