Old 10-04-2016, 12:13 PM
Both of those engines are different around these parts.
Glad it's back on the burner.
Old 10-04-2016, 05:26 PM
GPR's Avatar
GPR GPR is offline
The owner decided he didn't what the Shelby/Eleanor taillight panel that was installed before he bought the car. Brian had the fun job of cutting off the fiberglass taillight panel and end caps.
We bought another taillight panel to cut out the stock taillights.
After a lot of measuring and Brian standing back looking at them to make sure they were straight he welded them in place.
Since we have a side gas filler we decided to do away with the original one.
Brian cut out a section of the new taillight panel and welded it in place.
After a little grinding
Stay tuned for more modifications to the rear in the future.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 10-05-2016, 04:55 PM
GPR's Avatar
GPR GPR is offline
Brian finished grinding the right side.
Carriage bolts were welded to the taillight panel and ground down to hold the taillights
He still has to finish the right side. He bolted it together and tack welded the carriage bolts removed the taillights and finished welding both sides. This is how they look before he grinds them down and weld them one more time before the final grinding.
Rusty Gillis
Port Richey Fl
Old 10-06-2016, 07:32 AM
jarhead's Avatar
jarhead jarhead is offline
Rusty,
Nice work you and Brian are doing!
What will be the process you use for finishing off the undercarriage? Will it be primed, painted, undercoated?
Thanks, Joe
joe
Semper Fi
My 68 Torino
Old 10-06-2016, 05:40 PM
GPR's Avatar
GPR GPR is offline
Originally Posted by jarhead View Post
Rusty,
Thanks, Joe
Whatever the owner wants.
Rusty Gillis
Port Richey Fl
Old 10-06-2016, 05:41 PM
GPR's Avatar
GPR GPR is offline
Brian finished welding and grinding on the taillight panel
Rusty Gillis
Port Richey Fl
Old 10-06-2016, 08:16 PM
Very clean! Love the way the taillights are just there without a bezel to clutter up the area.
Old 02-25-2017, 10:15 AM
GPR's Avatar
GPR GPR is offline
We decided to install a roll bar and I bought a kit from S & W for a 1968 Mustang
We wanted to do something different so we cut about 1" off the end caps and spoiler.
As you can see in this photo the bumper needs to be narrowed
I cut the center out of the bumper and lined up both ends with the end caps.
I will have to add fiberglass to get a tight gap
Bumper fits better now but still needs a lot of work to look right
The gap was larger in the middle so I added fiberglass
We also added fiberglass to the bottom of the bumper
Rusty Gillis
Port Richey Fl
Old 02-25-2017, 01:08 PM
GPR's Avatar
GPR GPR is offline
The end caps were bolted and bonded to the quarter panel
I also added a little fiberglass
Bodywork ruffed in
We now have a nice tight gap around the rear bumper
Epoxy primed
Next step is to finish the bodywork on the taillight panel and rear valance
Rusty Gillis
Port Richey Fl
Old 02-27-2017, 12:37 PM
I love when they bring the rear bumper in tight like that, it looks so clean. Nice work.
