Old 05-18-2017, 06:36 PM
DBasher's Avatar
DBasher DBasher is offline
I'm always interested in used Ford parts. Concentrate on the new motor and keep me posted on the old.
Old 06-06-2017, 03:57 AM
70 tt rustang's Avatar
70 tt rustang 70 tt rustang is offline
Hi iam looking into getting that maier tower brace. I have efi on my Windsor thou, have you had any issues with valve cover removal or dizzy removal?
Also did you paint the bar?
Old 06-06-2017, 10:52 PM
DBasher's Avatar
I've got one on the wife's car and have no issues with clearance. Valve covers clear fine and just take a bit of routing to get them out, the distributor is close but removing the cap makes R&I a lot easier.
I think Ford and the aftermarket have different height distributors, probably best to call Mike. I know he'll make the bars to any angle needed.
Mine came powdercoated.
Old 06-08-2017, 03:48 AM
Thank man
Nice ride
Old 06-08-2017, 06:35 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
New engine should be a good amount of fun!
Old 06-08-2017, 03:13 PM
Try2paz's Avatar
Try2paz Try2paz is offline
Mine also came powdercoated... no issue with the valve covers going in our out but the distributor is tight but it works. I've got a MSD pro setup.
Some motor pulling fun!
I got the motor with the car and didn't know much about it other than it being a 351...i think it had a flat cam from the start as it should have been a "healthier" motor so to speak.
This motor has the right components to be a good motor so it will also take a trip to the machine shop.
I just dropped of the car at Mike's Maier and we're going to pulling the shock towers and covert over to 67 towers. So while the motor is being built a little extra work up front is going to take place.
1967 Nova
2018 Camaro ZL1 1LE
Old 06-08-2017, 04:51 PM
booah booah is offline
Mike Maier Inc now sell a DYI shock tower brace so you can get the clearances you want and have the same pick up points.
https://mikemaierinc.com/product/mus...k-tower-brace/
