Old 12-05-2017, 08:29 PM
slimjim's Avatar
slimjim slimjim is offline
Originally Posted by elwaupo View Post
I’m looking at one and it’s 52” from flange to flange and the stock width for the 69 Camaro is 59”.
So 52” should work?
Short answer is yes, 52" WMS to WMS will work, as long as you buy wheels accordingly..
Mine is 53", I also tried my wheels on a 52" rear end on another car, however my wheels are 12" wide with a backspace of 5.25". So if wheels this wide aren't in the plan, then you may want to go a wider rear end.
NC
streamline 68 camaro
Build Thread here
Old 12-05-2017, 08:50 PM
elwaupo elwaupo is offline
I am planning on going with wider wheels over the stock 15”x8” Rally’s in the back and wider then 15”x7” Rallys up front. Thanks for the back space information, very helpful. I’d like to run 17” all the way around as I’m planning on going with bigger brakes.
Old 12-05-2017, 09:51 PM
craig510's Avatar
craig510 craig510 is offline
Are you going to autocross? I like square wheel and tire packages so I can rotate tires easily. Pick your wheels out first. Mock it up and then measure, then you can get the rear end right the first time.
Old 12-06-2017, 07:11 AM
No this will be just for street but you never know🧐
