Old 11-14-2006, 11:41 PM
jonny51 jonny51 is offline
Originally Posted by Steve1968LS2
You guys are weak.. photobucket is for chumps.
host over at www.siihp.com (don't ask what that stands for).. you can post pretty big files and it's free..
Plus you can IMG tag them
My work here is done.. I need to go polish the bling yo...
Who you calling a chump?
Old 11-15-2006, 09:15 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Originally Posted by #1 STUNNA 67 IMPALA
IM DOING A PROTOURING 67 IMPALA THIS IS MY FIRST HOT ROD SO I'M NEW TO THIS BUT I'VE GOT A IDEA ON WHERE IM TRYING TO GO WITH THE CAR! ANY INSITE OR DO'S AND DON'TS ARE APPRECIATED! THANKS!
Welcome to the site. I can help you with the image posting if your pics are too big for the uploading size restriction I have on the Forums.
My LS7 69 Camaro
Old 11-15-2006, 09:32 AM
907rs's Avatar
907rs 907rs is offline
Can't really help you with the do's and don'ts, but you may want to check out SC and C for performance enhancing suspension parts.
Cool car. I've always liked the big bodied Chevys.
Bill
Old 11-15-2006, 05:20 PM
#1 STUNNA 67 IMPALA's Avatar
#1 STUNNA 67 IMPALA #1 STUNNA 67 IMPALA is offline
Default Ok
THAT WOULD BE GREAT! SO WHAT SHOULD I DO?
Old 11-15-2006, 05:29 PM
Turn off the caps, then e-mail them to Scott or me.
Old 11-15-2006, 05:48 PM
3kidsnotime's Avatar
3kidsnotime 3kidsnotime is offline
When I try to load pics which i have alot of the browser is saying they are to large! Anyone know what i'm doing wrong or how i can resize them?
Oh yeah! Thats the description of a stunna!
If you dont want to host your pic's you can right click on your pick select open with paint then on the top left click where it says image open with stretch/skew on stretch where it says 100% and 100% change to 70% on each to start select ok close pic then try, if they are still big do it again but only go 95% second time good luck
Old 11-16-2006, 12:03 PM
Default More Pics!
More Comming
Old 11-16-2006, 07:42 PM
awr68's Avatar
awr68 awr68 is offline
Welcome!! The car looks good from what I can tell from the pics!!
Tony
'68 Camaro
Old 11-18-2006, 03:33 AM
deuce_454's Avatar
great project, reminds me of the heavy metal II 65 impala that car craft did in the early 90 ies..
what you really need is stiffer bushings, thicker sway bars and better shocks, you can either box the oem controll arms or do like some mentally challenged people on this board (like me) spend a fortune on tubular controll arms..
but i guess if you are a real serious you should propably talk to marcus at SC&C and get a set of controll arms.
Old 11-18-2006, 01:23 PM
novanutcase's Avatar
novanutcase novanutcase is offline
DAMN BROTHER! That's a tight little ride you got there! When you type try doing it in lower case. All caps means that your shouting or speaking in a raised tone of voice. Helps so that people know when your trying to make a point.
Oh! BTW(By The Way)......Welcome to the site! Your car and the way you view it and other cars will never be the same!
