  #34
Old 05-01-2019, 07:52 PM
blitzer454 blitzer454 is offline
Actually the tail lights are also LED ones (LED boards) from United Pacific, which plugs into the 1157 bulb holder. I do not think the issue with the tail lights.
Originally Posted by 72Z/28 View Post
As far as the side markers, yes they were modified to blink with the turn signals. The ground wire has been connected to the parking light blinker wire, and they blink only when the parking lights are on. In other words, if the parking light is and the turn signal or 4 way flasher is on, the side markers do not blink
That won't work with LED bulbs as the current required to light an LED is much lower than what it takes to light and incandescent bulb. Reconnect the ground wire back to ground and all should be good.
