Old 05-20-2019, 09:01 PM
firebob's Avatar
firebob firebob is offline
Default Shocks
Thanks for the recommendations. I ended up with a pair of QA1 single adjustable shocks. Now the issue is I am running stock lower control arms and the shock body is bigger than the hole it's supposed to go through. If I cut/grind it big enough I will severely weaken the mounting area. I'm thinking I may need to break one of the ball joints and slip it inside the springs and button it back up. Hopefully I won't have to R&R shocks very often.
Robert
https://youtu.be/eaWBd3M9MN4
