  #31
Old 06-23-2019, 05:56 PM
SSLance's Avatar
SSLance SSLance is offline
I'm not going to sugar coat it...had a couple of pretty frustrating days in the shop.
I finished up putting the hose ends on the lines Friday and actually got pretty good at it by the end.
This "third hand" I picked up really helped with the process
Wish putting the tank in went as smooth. My guess is the new replacement tank is a smidge larger than the OEM tank and I struggled getting the old straps around the tank and installed. What should have taken about 15 minutes took a couple hours. Then I had to run the fuel line and my desire to make it as fit and finish as OEM led to more frustration. Between being larger diameter and stiff...I had a fight on my hands, but I got it done. I quit for the day and decided to wait until I was fresh Sunday morning to fire up the pump and test for leaks. Good thing I did...
Had the wife in the car to turn the key while I had the throttle body end of the line pointed toward a container so I could rinse the lines out before connecting to the throttle body. I had blown the lines and filter out but didn't want any trash from the pump getting into the injectors. She turned the key...nothing...
Sent her on her way and I started to chase down why. I'll save you from the horrid details but just know it wasn't until the fuel pump was back out on the bench (yes I had to drop the tank again to get it out), had jumper cables on the pins and a battery charger set at 20 amps powering them...that it finally decided to come to life. I then slowly reinstalled everything while testing the pump operation each step of the way. Once pump was back in the tank and tank raised up to installed location and all connections made, I hot wired the pump at the relay and I had fuel coming out the throttle body end of the line...and out from under the car... Seems I should have put a wrench on the inline filter housing itself to make sure the end cap of it was snugged down. Once that mess was cleaned up and line connected to throttle body again, I tested it again and NONE of my hose ends leaked... Woo Hoo! I cleaned up, aired the shop out and went in the house for a shower and a rest while the battery charged back up.
I just now returned in from the shop where I sat down in the driver seat and configured the handheld with my engine specs and uploaded the file to the ECU. I then did the TPS autoset and verified that all sensors are operational. The final screen said we are now ready to start the engine!!!
Well, kinda... I still have to fill cooling system and tighten the belts... THEN we'll be ready to fire it off.
I guess if it was easy, everyone would be doing it right?
Lance
camcojb (06-25-2019)
