Old 06-13-2020, 06:56 AM
Default chemically cleaning plastic grill
I have a black grill for a 68 Camaro (non RS) and was prepping to paint. I sanded,washed with soap and water, wax and grease remover. Then I sprayed with an adhesion promoter and it lifted big time. Back to square 1 not sure if there if it can be soda blasted or chemically dipped to clean it down to the base. Anyone have any suggestions?
Old 06-13-2020, 02:26 PM
slimjim's Avatar
slimjim slimjim is offline
I once attempted to overhaul my original grill but eventually gave up. I didn't have the same issues as you which led me to that decision, however the reproduction grill painted easily.
NC
streamline 68 camaro
Build Thread here
Old 06-13-2020, 03:48 PM
dhutton dhutton is offline
Some plastics don’t need adhesion promoter. Cut off a small piece and place it in water to see if it floats. If it’s a floater you need promoter.... If it doesn’t float then no ad pro is needed.
Presta Scuff Stuff is a good way to prep parts. Then apply a good epoxy primer such as SPI.
The Following 2 Users Say Thank You to dhutton For This Useful Post:
572Camaro (06-14-2020), RdHuggr68 (06-13-2020)
