Old 03-25-2005, 03:58 AM
Stielow's Avatar
Stielow Stielow is online now
Default Looking for LS1 / T56
I'm lookinf for a 2001-2002 F-car LS1 and T56 power train for my next project. Complete drop out all accy.
Any leads or contacts would be appreciated.
Stielow
Old 03-25-2005, 05:23 AM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
Have you checked at eBay?
I usually check there for a setup like that but at the moment I only found some from a '98.
Charley said that you were going over to Nurberg ring later this year. How are those plans going? I might do it myself, just one days drive from where I am, maybe we could see each other there?
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
www.protouring.se www.carphotos.se
Old 03-25-2005, 07:43 AM
galopin galopin is offline
Default Leads
http://www.ls1tech.com/forums/forumdisplay.php?f=45
This forum has a very active "For Sale" section. It would also make sense to post this in the "Parts Wanted" section there as the site has a huge membership--more eyeballs, more leads.
Also, I missed your message this morning. Good luck.
Old 03-25-2005, 01:55 PM
Rybar's Avatar
Rybar Rybar is offline
I posted a wanted ad on LS1 Tech and had quite a few people with setups for sale, also try Ebay, e-mail some sellers if they have any other stock. I did find a few setups that way, but was like you looking for a 2001+, the Ebay sellers will be more expensive than a seller on LS1 tech. And watch out for scammers, I had guys sending me pics they pulled off ebay so I would send them money, so be weary. If the deal is too good to be true, then it is!
I did get mine through a seller on LS1 Tech, found the best deal there. 2002 F-body LS1 with T56, all accecories, wiring harness/PCM, rad/fans, exhaust etc for $3800 + shipping.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 03-28-2005, 10:16 PM
Mark-
Try John Wilson, formerly of Flowmaster Mufflers. He does F/Y body salvage and can usually get or has on hand most items you'd want. Tell him I sent ya.
[email protected]
Tyler
Old 03-30-2005, 01:16 AM
Default John Mr Wilson
Hey Tyler, is he in California? still?
Vince
Old 03-31-2005, 02:14 PM
rwhite692's Avatar
These guys may be worth a call.
http://www.gmsports.com/
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 04-01-2005, 06:09 PM
1973-Turbo-LS1-Camaro's Avatar
1973-Turbo-LS1-Camaro 1973-Turbo-LS1-Camaro is offline
You might want to try:
Shaun Carter
SMC Performance, Inc
248.276.0483
[email protected]
I have always been able to get things from him as he deals in a ton of LS1 stuff..
Don't know if this will help you or not but I have an LS1 block, crank and 15-16 stock rods/pistons sitting on my shelf that I would like to get rid of. It will need a rebuild (Gaskets bearings ect).. PM me if your interested in it.
This is everything I have to get rid of:
98 Block
Crank
98 Heads (Complete)
Oil pump
Valve Covers
Fuel Rails
28lb Injectors
LS1 Intake
LS1 Valley Cover
Stock Manifolds
Throttle Body
Crank Pulley
Wires
Shaun Liddy
Super 73
Martz Rear Suspension
Wayne Due Front Subframe
Boosted LS1
Garrett T91
AFR 225 Heads
D&D 6 speed
Moser 9"
Gen 7+
Old 05-05-2005, 03:13 PM
david@ronsraceshop's Avatar
david@ronsraceshop david@ronsraceshop is offline
Stielow
Just wondering what new project your doing now?
any hints?
David@RonsRaceShop
VP RonsRaceShop
1971 RS Camaro
SBC 396 cid .... Comming Soon
ATS Spindles ..... Comming soon
14" Corvette Brakes with 6 piston Calipers ... Comming Soon
Tremec TKO-600
ROH 18x8 Front Toyo Proxes T1s
ROH 18x10 Front Toyo Proxes T1s
100-0 .... 185ft
60-0 ...... 110ft
13.40 1/4 mile
109 MPH 1/4 mile
Old 05-05-2005, 03:58 PM
RPO1LE RPO1LE is offline
You might want to give these guys a shot. He had several when I was considering the same swap.
Hope this helps!
Billy Graham Camaro Salvage
Rob
