Old 12-10-2006, 07:21 AM
awesometool's Avatar
awesometool awesometool is offline
Question DSE back spacing
I have read all the posts on DSE tub kit with quadralinks but do not see any thing on 18" x 11.5" rims with ?7.5" back spacing. The shop that is doing the work recommended these wheels sizes and 315-40 for tires. I don't see anyone with 7.5 back space?? It would be nice to have 18" x 12" with 335s but DSE said 315 if you going to drive it hard. I have stock style moser rear end and bear sport track brakes.
Old 12-10-2006, 10:47 AM
that's a lot of bs for an 11.5" rim. I prefer less just for looks but there's no big problems running that I guess.
It all depends on the rear end width. Most use a rear end in the 56.187" width and a 18X12.5" wheel and 6.375 to 6.5" b.s. Also most run a larger tire than that as there's plenty of room. 335/30 is the most common but the quadralink allows a 345 if you wanted.
Don't use the above numbers as absolutes, you have to do your own measuring. But the above combo has been on a few cars and works. All depends on what width rear end you're using.
Old 12-10-2006, 11:46 AM
stevehoj stevehoj is offline
Budnik Arrowheads, stock rear width (12 bolt with drums), 15 x 12" rim w/ an 8" BS. I know, old school.....but set up for drag racing.
Not sure on the 18" wheel diamater.
Old 12-11-2006, 02:13 PM
dplenzig's Avatar
dplenzig dplenzig is offline
On my 69 mini tubbed with quadralink the backspace with stock rearend and 18x12 was 8", I narrowed the rearend 5" and went with 5.5" bs for the lippy look. So 18x11.5 with 7.5" bs would have worked on my stock rearend.
Daren
Old 12-13-2006, 05:24 PM
Thank you for the advice that is exactly what I needed to know.
Old 12-15-2006, 10:39 PM
awr68's Avatar
awr68 awr68 is offline
Is that a 67-8 camaro? If so DSE is right by saying the 315 is a better fit. The 335-345 tire truely fits better on the 69's due to their wider outer fenders. Yes a 335 will fit under a 67-8 but you have to roll the lips and do a 3" tub and it's still a tight fit.....personally I like my 315's, they fit well and are a balanced match to the front 245's.
Tony
'68 Camaro
Old 12-18-2006, 09:24 PM
Spoke with dse today they said 68 camaro will fit 335 with budnik ice 12", 5 1/2" back space, 1/2" spacer 53 3/4" rear end. They said no need to roll lip but many people say you do? 3,000.00 for rims and 1,800.00 tires so if roll has to be done I will have to do it now as it is getting painted soon.
