Closed Thread
Old 11-30-2023, 05:34 PM
Stielow's Avatar
Stielow Stielow is offline
Stielow Engineering
The Following 5 Users Say Thank You to Stielow For This Useful Post:
Aschle (12-01-2023), camcojb (11-30-2023), fleet (12-01-2023), srode1 (12-01-2023), WSSix (11-30-2023)
  #192
Old 12-01-2023, 04:30 PM
Stielow's Avatar
Stielow Engineering
camcojb (12-02-2023)
  #193
Old 12-01-2023, 04:32 PM
Stielow's Avatar
Stielow Engineering
The Following 7 Users Say Thank You to Stielow For This Useful Post:
89 RS (12-03-2023), camcojb (12-02-2023), fleet (12-01-2023), NAPA 68 (12-03-2023), srode1 (12-01-2023), syborg tt (12-01-2023), WSSix (12-03-2023)
  #194
Old 12-04-2023, 08:46 AM
ScotI ScotI is offline
Default DBW TB Adapter?
Mark,
What adapter was used for the intake that allows this packaging? I was looking into an aftermarket style body but I'm intrigued about possibly using my existing 6.0 DBW unit.
Or if you know of any other details on this I can research/investigate that you could share, it would be appreciated.
Old 12-04-2023, 09:50 AM
Originally Posted by ScotI View Post
Mark,
Probably this or something similar.
https://www.summitracing.com/parts/h...xoCS1sQAvD_BwE
  #196
Old 12-04-2023, 10:06 AM
This is what I was hoping for (available vs something that was one-off built).
TY sir.... I'll check into it.
camcojb (12-04-2023)
  #197
Old 12-04-2023, 10:09 AM
jeff71 jeff71 is offline
Here’s some I know about.
https://www.delmospeed.com/product-c...body-adapters/
https://www.lsclassic.com/intake-sys...ir-cleaner-kit
https://www.psiconversion.com/CLASSICLS/THR-9930.html
The Following 2 Users Say Thank You to jeff71 For This Useful Post:
camcojb (12-04-2023), ScotI (12-04-2023)
  #198
Old 12-08-2023, 10:11 AM
Stielow's Avatar
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
camcojb (12-08-2023), Roscoe03 (12-15-2023)
  #199
Old 12-08-2023, 12:06 PM
Ok this has been fun. Going with caps. Blue or Black wheels.
Since you drive your stuff..... My vote is black wheels. VHT Epoxy Satin Black is very easy to source & use for touch-up needs @ any time. I use it on my steelies for just that reason.
  #200
Old 12-08-2023, 02:44 PM
Stielow's Avatar
Default Hobbs Camaro (Old Drag Car)
Originally Posted by dhutton View Post
Looks great. I am curious if you feel those exhaust manifolds flow better than the GM stainless tri-y manifolds.
Thanks,
I don’t have any data other than “looking X guessing”. I would bet the stock LS7 Camaro Z/28 Tri Y headers will make more power. The GM Powertrain team did a lot of work on those Z/28
Manifolds to get over 505 HP stock.
I have made over 800 HP with the Holley exhaust manifolds on a blower motors.
Both are good. The Holley’s fit the “look” of the engine bay better.
Mark
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
camcojb (12-08-2023), dhutton (12-08-2023), fleet (12-08-2023)
Closed Thread
