Old 08-01-2023, 10:12 PM
camcojb camcojb is online now
You are way too busy my friend...
Old 08-31-2023, 08:23 AM
EVIL SS EVIL SS is offline
My number one question about my cars is “What is the wheel offset”? Over the years we have found it easier for the rear wheels to order the wheels then build the axle to fit. It is easier to modify the axle tube than it is to get new wheels.
I was going to use a retro wheel, but I could not get the brakes to fit. The crew at Forgeline did a lot of work to attempt to get it to work. For me form follows function. I really wanted a retro wheel but I think these look great. If I really want the old dog dish look I’ll swap the brakes to sliders and order new wheels.
Looks great so far!! I you assume start with a known offset and adjust from there? What brakes are you going to run on this car?
Old 08-31-2023, 08:47 AM
Stielow's Avatar
Stielow Stielow is offline
Default Hobbs Camaro (Old Drag Car)
The Detroit Speed subframe works well with a 18x10 front with a 20 mm offset or 6.25 backspacing. The rear we ordered a 18x12 with the most backspacing that Forgeline could do in there forging. Off memory it as 19 mm offset 7.25 backspacing.
I think I will have 2 sets of brakes for this car. The track setup with the Brembo and Monoblock Forgeline wheel (Pictured below). To keep with look of the car I’m going to order new Forgeline OE wheels that will take poverty cap hub caps. For the OE style wheel I’ll need to run stock C6 Corvette brakes. For just cruising around the OE black steel looking wheels will work well.
The Forgeline OE wheel
Stielow Engineering
Old 08-31-2023, 08:52 AM
Stielow's Avatar
Matt is back to working on my car. He cranked on it to get it to my Car Party as a roller.
The only real rust on this car was the dash at the base of the windshield. I dislike the look of the repo dash top so Matt tuned it up to look more stock.
The repo speaker grill doesn’t look right. Matt swapped the stock one back into the dash.
Stielow Engineering
Old 08-31-2023, 09:03 AM
srode1 srode1 is offline
Did he redo the VIN hole to match original or did you get a top that does look correct?
Old 08-31-2023, 09:04 AM
Stielow's Avatar
Yes
Stielow Engineering
Old 08-31-2023, 12:43 PM
Thanks Mark! Is this the same setup as your LT5 car with custom hats? I'm still looking for a good front brake setup for my LT5 build.
Old 08-31-2023, 12:53 PM
ScotI ScotI is offline
I was curious what the OE1's allowed as far as brakes (aggressive brake packages or limited to production based).
Old 08-31-2023, 12:55 PM
Stielow's Avatar
Yes similar set up. I had Howell make custom rotors for the back with the stock ZR1 hats.
Brakes are a personal choice. I like the Brembo stuff because I know it and I know the Brembo engineers, both on the production side and the racing side.
I know a lot of people are use a lot of other brands with no issues.
Stielow Engineering
Old 09-01-2023, 06:47 AM
Stielow's Avatar
You can run “Big” or oppose piston brakes with the OE Forgeline wheel. It just pushes the center out board and make the center cap look odd.
See attached photos. The outer rim half is not very deep and IMO the center cap pushed out like this is not my preference.
Stielow Engineering
