Old 12-28-2006, 02:42 PM
chevymitchell's Avatar
chevymitchell chevymitchell is offline
Talking Dse
What width rear end should I use in order to fit 335's under my 69 Camaro with the DSE mini-tub kit and thier Quadra-Link? I have been trying to find some info on this. I am wanting to install a 9" rear, just don't know the width of the housing assembly to use. Where would I take my measurements?
Shawn
Old 12-28-2006, 02:44 PM
camcojb camcojb is online now
The Mule uses a 56.187" housing width and 18X12.5" wheels with 6 3/8 to 6.5" b.s. This would of course change depending on the wheel offset you choose.
Make sure you measure yours up first as it may be different!
Old 12-28-2006, 02:56 PM
Thanks Jody...What rear end does The Mule use? Manufacturer?
Shawn
Old 12-28-2006, 03:48 PM
Currie with aluminum center section, basically a fancy 9"
