Old 03-19-2007, 04:20 PM
Marcus SC&C's Avatar
Actually the lengths of the links are much closer than you think,even in side view. The G Bars converge at a milder angle than GM factory cars and they make efficient use of the available space. The DSE upper arms are parallel and recessed into the unibody but they loose much of what they gained by mounting the rear end of the arms well forward of the axle tubes rather than directly over them like the G Bar. Both are clearly somewhat of a compromise of form for fittment BUT both have also proven to perform suprisingly well. Naturally the more you`re willing to chop the car up and the more money you`re willing to spend the less compromises you have to accept. The question I always ask clients though is,for them and what they`re really going do with their car for is that little extra bit of "juice" worth all the extra "squeezin"?
My statement on antisquat is based on seeing both setups in person. With the lower arms parallel to the ground for min. roll steer and as a std. of comparison the G Bar`s upper arms are angled more steeply than the QL`s which are nearly parallel. The QL is set up much more like a typical street rod "4 bar". You`ve seen them both at SEMA and such,I`m sure you noticed it too.
Honestly I wouldn`t use either on a GT1 or AGT road race car. But for a performance street car they offer some very nice advantages and the G Bar does so with no cutting or welding to the body or frame at all. At it`s price point it`s a heck of a good deal with the Alston Varishock 16 setting adj. coilovers and springs included for less than a base QL with no coilovers or springs at all. The QL is fine and I like the swivel links (which have been used in aftermarket 4WD applications for years BTW) but for all the extra work and money folks might as well spend a little more and get the Lat.Dynamics 3 link/watts link package. Mark SC&C
