Old 05-04-2005, 12:28 PM
XcYZ's Avatar
XcYZ XcYZ is offline
RoarVette, shoot me an e-mail: [email protected]
My LS7 69 Camaro
Old 05-08-2005, 06:53 PM
Red73 Red73 is offline
Great looking project vette. I'm going to love watching the progress on your vette. Rod
http://forums.corvetteforum.com/phot...cs0005-med.jpg
http://forums.corvetteforum.com/phot...cs0003-med.jpg
Old 05-08-2005, 07:06 PM
RussMS's Avatar
RussMS RussMS is offline
Great Looking Project.
Welcome to the Forum
Russ
Old 05-08-2005, 08:44 PM
USAZR1's Avatar
USAZR1 USAZR1 is offline
That's going to be an awesome ride,when done.
You're not using the stock 64 rear,are you?
Clint Hooper
Clint's 70 El Camino restomod Sold
Clint's 69 Elky Protourer Sold
Old 05-09-2005, 06:19 AM
Roarvette's Avatar
Roarvette Roarvette is offline
Default Differential
Hi,
Thanks for the comments. No, I'm not using the stock 1964. I had a unit put together with 3.7 gears, this gives me 40 MPH at 4500 RPM and 220 MPH at 5000 RPM in top gear.
It has a large yoke front yoke, new stub shafts, a carbon fiber clutch set and new ring and pinion gears.
It should work, well see. The car should weigh just over 2800 lbs.
Everthing that turns, from the engine to the back tires is brand new and much stronget than anything Chevrolet intended.
Thanks, again.
Roarvette
500+ HP, 500+ Ft. Lbs, 500+ Cu. In. Yeah the numbers match!
Old 09-28-2015, 06:28 AM
Roarvette's Avatar
Default Its Driving at the 1500 mile mark
Here is my car at the 1500 mile mark. It is reliable fast and very streetable for a car of this performance level. I continue to do odds and ends, but for now just love putting on the miles. Quickly...
Old 09-28-2015, 09:54 AM
Wow! Talk about a reviving an old thread. Glad to see the car was completed or at least put on the road finally. How did it feel to finally get to this point? Congrats!
Old 09-29-2015, 06:05 PM
87SS's Avatar
87SS 87SS is offline
Default I want one!
More build pics. please.
1976 Trans-AM
1987 Monte Carlo SS
1989 MR2
1995 Trans-AM
Old 11-01-2015, 09:33 AM
alongfortheride alongfortheride is offline
More pics would be great. What are those headlights from?
Old 11-09-2015, 08:37 AM
Roarvette's Avatar
The headlights are Hella 90mm rally racing units, very light which was the whole point. They are mounted to a thin steel plate that was welded to the headlight mechanism mounting plates, then fared in with fiberglass.
The LED parking/turn signals are something I found on EBay.
The Poly-carbonate (Lexan) covers are 1/16' thick and are formed in a bending brake, just like sheet metal, and then just screwed on, just like a race car.
