Old 05-26-2007, 11:02 AM
dplenzig's Avatar
dplenzig dplenzig is offline
Default Fast xfi harness placement
I am doing a Fast xfi on my 69 camaro and wanted some ideas of where people are mounting the ecu and running the harness thru the firewall.
Daren
Old 05-27-2007, 08:15 AM
parsonsj parsonsj is offline
Default XFI Placement
Daren,
I put mine in the glove box area, and used a Mil-spec connector to run it through the firewall near the driver's side head. I combined several wires to get that to work, both for the ECU and for my AutoMeter gauges. That allows me to completely disconnect my engine wiring with a twist, click, and a tug.
jp
John Parsons
Old 05-27-2007, 09:37 AM
68protouring454's Avatar
john, any pics and or links to the part you used or ones like it??
thanks
jake
Old 05-27-2007, 04:09 PM
Default Wires and Pliers
Jake,
I got my stuff from Michael Browne (he goes by Sparky). His website is http://www.wiresandpliers.com
jp
John Parsons
Old 05-27-2007, 04:26 PM
camcojb camcojb is online now
Originally Posted by parsonsj
Jake,
jp
same here, he wired Malitude, and will be re-doing my engine harness for the swap from Electromotive (yuck!) to BS3. Extremely cool stuff.
Looks like this:
Old 05-27-2007, 08:22 PM
thanks guys, plug looks like it is alittle long, is it?? or can it fit in an inch spot behind a head etc??
thanks again
Old 05-27-2007, 09:47 PM
Default Fitment
Sparky can sell you a 90 degree boot, but you'd probably be a lot better off with 2-3 inches of clearance.
jp
John Parsons
