Old 07-21-2016, 10:10 AM
Sonar Chief's Avatar
Cool /Update
Finished the bracket mock up on the 9" and then did a little of this and that, you know the stuff you have been putting off for awhile .... sprayed some epoxy and cut and re-weld the rear quarter corner that didn't fit follow the OEM tail panel!
I am waiting on my sway bar axle brackets from RT, seems I misplaced the originals,huh? And my rear axle alignment tools should be here soon so I can get the brackets welded in place for good.
Not much of an update but it's progress .... thanks for looking!
Old 07-21-2016, 01:57 PM
paulk68 paulk68 is offline
Looks great, Man I wish you were closer I would hire you to install my ridetech 4 link and rear end. Keep the updates coming!!
Old 07-22-2016, 02:48 AM
grendel grendel is offline
Looking good Chief. We racing soon?
My garage builds, with some hack and professional love thrown in:
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
Old 07-22-2016, 03:18 AM
Looks good chief. Don't feel bad about misplacing the sway bar bracket, when I'm done with my build I'll have enough lost part left over I'll be half way to a second build!
Old 07-23-2016, 10:59 AM
Cool Update 7/23
This is my second time fitting brackets, it's just time consuming to get them to fit snug that's all!
Thanks JJ, she's getting there, my goal is to finish this version before Thanksgiving!!!! Well, that's my goal ....
Yeah I hear ya, just feel bad calling and getting more parts that I lost somewhere ....
Got the second set of sway bar brackets from RT, Thanks guys ... got them mocked up and tacked in place, now I can get all the brackets welded for good.
I had one of those "what the halibut" moments, there is no way an exhaust pipe is going to fit in there with all this stuff ....guess I'm going with an under axle exhaust. Take a look and see if there is something I'm missing here ... besides space for an exhuast!
Oh yeah, I fiddled with some filler on the outer wheel house and made a big mess.
Back out to the garage, thanks for looking ....
Old 07-23-2016, 07:31 PM
Cool
Good garage day fer sure ... man was it hot though! I love it when a plan comes together, figured I'd best get the passenger side micro-tub going before I installed the driver's side. Broke out the plasma cutter and used my template from the driver's side, took a few measurements, and .... the first time I put her in the tub follows the quarter panel to a T! That's kinda scary
Anyway, thanks for looking ....
Old 07-23-2016, 09:44 PM
Zoomin Zoomin is offline
Fine looking build, that's for sure. Looking forward to seeing it setting on all four.
1964 Lemans
1966 Skylark
1969 Camaro
Old 07-27-2016, 08:08 PM
Cool
Thanks, me too!
Working in the garage when it's not so dang hot got most of the micro-tub welded in the last few days, need to final fit and get the vertical close-out cut and welded in .... phew that'll off the list!!!
Then the brown truck showed up today with my radiator .... nice unit fer sure, but there is a lot of wiring in that box, guess I'll have to do some reading soon.
More tomorrow, thanks for looking ...
Old 07-28-2016, 04:22 AM
New fan mounts? Mine are just black plastic... off to call Tony.
68 GMC C1500
73 Camaro
Old 07-28-2016, 06:46 AM
syborg tt's Avatar
Nice progress as for the exhaust any chance you can remove some of the trunk floor and go into the trunk around the tank and come back down.
Not sure what tank your using but you can also consider using a mustang style tank that drops in from the top and give you plenty of extra space for exhaust.
You can see that the well in the trunk has been removed and the tank has been elevated up to make the trunk floor flat. Which also hides the tank and allows you
to place a crash bar across the rear frame rails to protect the tank at the back of the car.
marty-mj
