Old 05-05-2009, 01:23 PM
rwhite692's Avatar
Looks good, as I was reading the first couple of posts I was saying to myself, "he's going to have to modify the K-Member...." LOL! Glad you are going this route, it will look so much better.
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 05-05-2009, 01:54 PM
tjbruning tjbruning is offline
I agree - the ride height was high. Are you going to have to notch the rear frame to tuck the axle ?
No, plenty of clearance between the axle and the frame rail. After modifying the upper shock mounts, there will be ~3 1/2" of clearance at the new ride height.
Old 05-05-2009, 01:58 PM
Originally Posted by Musclerodz View Post
As many K members i have heard about being modified this way, I am suprised they have not changed the design. looks awesome
Most of the Mopar suspension kits are designed to bolt-in with minimal fabrication. Ned's already past the point of no return...
Old 05-05-2009, 02:00 PM
DRJDVM's '69's Avatar
No I shouldnt have to notch the frame in the rear...its not going to be that low... I think ...I may have the notch the rear crossmember so the pumpkin doesnt hit....but I think the axle tubes should be fine
As for the k-frame design....the RMS (and the other 2....Magnumforce and XV) is really designed for "less aggressive stance" of a car...i.e not running 19 inch front rims and 20 rears.....not shooting for the total "in the weeds" look etc. It has a much bigger market of the "average guy" thay just wants to get rid of the 30 year old torsion bar style suspension in the Mopars...plus there are just fewer guys cutting up Mopars and doing wild stuff... their numbers are growing but not nearly as many as Chevy and Ford etc.
So I cant fault RMS for staying more "in the middle of the road" for their design
Old 05-05-2009, 04:51 PM
bentfab's Avatar
bentfab bentfab is offline
Know the feeling !! This started out as an XV back half. What's left is the lower control arms and shocks.
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
Old 05-05-2009, 05:34 PM
rwhite692's Avatar
Mark that is a sweet setup you have there.
My Lateral-G Page
My Shop Build:
Old 05-05-2009, 08:14 PM
yeah with the old 20/20 hindsight, I should have just bought the Shockwaves and had everything fabricated custom. Probably would have been close to a wash as far as overall price....
Well probably not....but the overall custom design may have been worth the extra $$....mounts on th rearend rather than bolt on with U-bolts etc etc etc...
One comment on the Air Ride.... the plate that holds the U-bolts is bending already...would have been nice to be alittle thicker.... I'll fix that once I get the rearend finalized.
Old 05-05-2009, 08:51 PM
bentfab's Avatar
Thanks alot.
Old 05-06-2009, 04:18 AM
MoparCar MoparCar is offline
With the lowering of the car in the rear, will you have to modify your outer wheel tubs for clearance? Basically doing a "bump" to the outer to make room for the tire? The mini tub does the inside nicely but so many mopars are tight on the outer. Without sucking the tires in they are very close to the outer tub as I'm sure you know. I'm building a Challenger and I keep looking at this while doing mock up that's why I'm asking and looking for ideas from a Pro Build.....
Thanks! Wes
Old 05-06-2009, 09:27 AM
96z28ss's Avatar
96z28ss 96z28ss is offline
Does look nice, lower.
When are you going to get wheels for the car?
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
