Old 02-21-2011, 03:11 PM
slenning's Avatar
slenning slenning is offline
Originally Posted by Rybar View Post
Interesting we all just noticed this now
I never noticed the difference before either. Heres a shot of my Profil 5's
Uploaded with ImageShack.us
Steve
70 Camaro - in process https://lateral-g.net/forums/showthread.php4?t=50636
69 Camaro LS7/T56 https://lateral-g.net/members/lenning/
69 Camaro SS396/350hp
64 Chevelle - patiently waiting
2014 Z28 Ashen Gray
2010 Camaro 2SS/RS Black w/White stripes (wife's car)
2015 SS (the 4 door one) Wife's other car
Old 02-21-2011, 03:20 PM
coolwelder62's Avatar
Finally got a nice day, took the car to work. Sorry for the crappy point and shoot pics and the car is filthy. Going to detail it up this weekend.
The Fikse wheels are awesome.They look perfect on your camaro. Scott
Old 02-22-2011, 07:12 AM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Looks like I'll be modifying my G-Link to get the ride height as well. I noticed the same thing on mine after I installed it. Of course, once it's welded in there's not much you can do.
The car looks great, Ryan.
Chris
Old 02-22-2011, 08:52 AM
pokey64's Avatar
pokey64 pokey64 is offline
Your car looks great with the new wheels Ryan! I love the color. The stance looks good to me.
Chris, Are you thinking about running shorter springs or modifying brackets and trunk floor? I'm working on a G-link install on my wife's 69 currently. I've only welded points that can be cut easy so far. If you or anyone else has thoughts on this we could start a new thread so we're not hijacking Ryan's.
//Ed
//1964 Impala SS
//1966 Chevelle (Family Hauler)
//1969 Camaro (Hers...)
Old 02-22-2011, 10:45 AM
Rybar's Avatar
Rybar Rybar is offline
Thanks Chris, this is tough to say. When Frank sold me on the G-link there weren't alot of cars with it actually installed that he could show me pictures of the ride height as low as I wanted it to sit. There were alot of guys running the older G-Bar/Air-bar/Prodigy-bar setup, but this G-link kit is a little different. Now I see that the G-link upper shock cross member under the stock trunk floor limits clearance for exhaust etc. So it's tough to get the car low like the Quadralink guys. On mine the shop ended up installing a shorter spring and moving the shock mounting points up. We also switched from the 175 lb springs to 200 lb springs. I find it rides quite nice with the 200 lb springs, especially compared to leafs which were much more bouncy and stiff, but I can't say I've driven it alot. And have definately not pushed it yet. The rear-end, tranny and clutch are all brand new and in the break in stage.
No worries to Hijack, I think threads like this are good for positive and negative critisism of parts. Just like Todd's Payback thread. Great that he's honest in his reviews good or bad. Everyone of our cars is a test mule for these companies as were all running different combos, be it engine, tranny, rear-end, frame connectors, wheels/tires, tubs, non-tubbed, exhaust routing, gas tank types etc etc.
Thanks again everyone for the positive comments.
Ryan
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 02-22-2011, 11:26 AM
Gandalf Gandalf is offline
Interesting observation Jay. I'm waiting on my 5s wheels and hope they have the crisp edge you mention - I like the way it has that center dish. It's a preference thing for sure. You car looks killer Ryan!
G.
Originally Posted by Jamess113 View Post
Hey I just noticed that Fikse changed the design of the centers. I'm looking at the pictures of your car and I'm thinking that there is something a little different about the front wheels. The area where it tapers in to lugs and cap is totally different. On my wheels and the one's on my customers car they have crisp edge before it dishes in . Your's just taper in.
Just an observation. I wonder why the changed them? They still look great.
Old 02-22-2011, 11:45 AM
Also not wanting to Hijack Ryan's thread. Good GBar conversation and I too am interested in this.
I have the ver1.0 GBar and was looking to run lower than I could get with the lowest settings. A shorter spring (9") got me there but I didn't like loosing the shock travel plus I'm not sure if I should be worried about using the coil-seat adjustment for altering ride-height. I'm always scared that top spring keeper is going to fly out under full extension. Not sure if that is a well founded fear but I note they always say that is for spring pre-load adjustment only. (then again - we were never supposed to cut coils from springs back in the day either).
So the easy way out would have been to go to a shorter shock AND spring but again concious of loosing shock travel. If I did it over again I'd try that route first. Instead I had a DSE crossmember in the garage so we installed that with the DSE top shock mounts and cut the GBar crossbar out. Definitely not an install to be taken lightly on an assembled car and I'd not do it again - what a PITA but that is definitely NOT the fault of the parts! So that actually acheived more that I was looking for (addtl 4"). I am running the lower shock mount up a few notches and inverted - i want to bring that back down again so now I'm looking at getting longer shocks to compensate.
Varishock makes a shorter shock and spring combo (in fact I have a new set here) and I would definitely try that first next time.
My 2c.
G.
Ryan
Old 02-22-2011, 12:04 PM
Rybar's Avatar
My 2c.
G.
Sounds like you as well would have been better off installing a DSE Quadralink.
1969 CAMARO RS
Old 02-22-2011, 12:07 PM
I hear you but the Gbar cradle is fully welded and Moser rear was built with GBar mods. Tough to go that far back to go forwards.
G.
Old 02-22-2011, 12:18 PM
Rybar's Avatar
G.
Understood, I meant deciding on a different suspension during the planning stages.
1969 CAMARO RS
