Old 05-07-2009, 07:58 AM
tjbruning tjbruning is offline
Originally Posted by bentfab View Post
This is with a 19 out back. I personally would like it a little lower but that's what the owner want's. These cars are a little tricky to make look right.
I agree on going a bit lower, but then again I like em' low!
19/20 combo
edit - Tim built a custom oil pan that doesn't hang below the car/chassis, so no less than 5" ground clearance at this height...
Old 05-07-2009, 08:00 AM
CAMAROBOY69 CAMAROBOY69 is offline
Now that stance looks perfect.
Adam_______Offical Car Name "ILLUSION"
383 Stroker, Stock cast heads, T-56 tranny, 4.11 gears, 2002 T/A dash, 4th gen interior including seatbelts, power lumbar seats, 18" Budnik Wheels,Hydratech Hydraboost
ILLUSION Website
--------------My Car on Lateral-g.net----------- Need something designed?-AdFabDesign
Old 05-07-2009, 08:01 AM
Originally Posted by DRJDVM's '69 View Post
I had to do a double take on the rim... it took me a minute to realize that you had the center but not the hoop
hoops are there, but black
Old 05-07-2009, 09:12 AM
DRJDVM's '69's Avatar
I looked again...hoops are there .....on the 3/4 view of the back it looked like I could see inside the tire itself...my mistake....its just the reflection on the hoop.....
Old 05-07-2009, 11:25 AM
bentfab's Avatar
bentfab bentfab is offline
Funny you say that. A buddy of mine came buy and was actually touching the tire and thought the same thing.
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
Old 05-07-2009, 11:29 AM
bentfab's Avatar
19/20 combo
T.J.
When I was first setting up ride hight I showed the customer those same pics. Problem is he's a little old school and likes them sitting a little higher.
Buy the way your car is BAD A$$ !!!!!
Old 05-07-2009, 11:40 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
I agree.
Looks killer!!
Old 05-07-2009, 12:06 PM
T.J.
Thanks Mark! Sounds like your customer is coming around for an "old school" kinda guy considering what your doing with his Cuda. Nice fab work as usual - looking forward to seeing the finished build.
Old 05-09-2009, 11:52 AM
Grimmey71 Grimmey71 is offline
Ned had the tubs done at the last shop and there is plenty of room. Also, Challengers are wider at the belt line than Cudas (1 1/2") which makes it difficult to bring the wheel out as far since there is less clearance at the top of the tire.
XV runs 335/30/18's on the rear of their cars and they told me all they had to do was roll the wheel lip. I was kinda hoping to do the same on my cuda. I dig the 19 inch tires and the look, but my srt4 came stock with 19 and the tire price is high and they dont make alot of different sizes yet that I know of. I guess I am just hoping for big rubber with less work
Old 05-10-2009, 07:02 AM
I dont know I believe that... the stock tubs are decent size but I think a 335 would be real tight. It also depends on how the car sits....if you dont mind it sitting kinda high and roll the outer lip it might just fit. Plus "fitting" and "fitting right" aren always the same thing. If you dont mind alittle rubbing from time to time, then okay.
A 315 probably but a 335 is cutting it pretty close in my opinion. And yes, the range of 19 tires is alittle smaller than the 18 or 20's
If you go to my pix link below I have some pix of the 335 being fit into the cut out stock tub location..... this was done at the previous shop, so don't pay attention to the quality of the fab work
