Old 09-23-2007, 02:15 PM
mazspeed's Avatar
mazspeed mazspeed is offline
Originally Posted by Steve1968LS2
Thier test car, running the subframe, was out a the Run Through The Hills autocross event and did VERY well. I think it was in the top 3, maybe even top two, times for cars on street tires (non-R-compound)
They also tested the car out here in CA at the El Toro Marine base. I can't release the numbers but the car did very good. I think it almost got a 1g on the skidpad. Again, on non-r-compound tires.
Their chassis uses a lot of DSE parts including chuncks of thier hydoformed subframe.
Anyways, it's a cool car and beat the snot out of it. lol
I saw that car at the last goodguys event here in Aug. They had a display of chassis and the quality looked killer. Yeah, that has a big block merlin right? It was nice, and had bugs on it, which means they drive it.
Old 09-23-2007, 03:01 PM
R67Chevelle R67Chevelle is offline
Reason for my interest is that the rear tires on a stock chassis is max 10" on the rear. On my chevelle the chassis is not rigid at all and want a firmer handling and more stable ride. The weight difference would be a interesting issue. Also the time is consuming in redoing the stock frame. It would be nice to roll a new chassis and be ready to finish the paint and body. The price after all the options are definately going to be over 20k and not too pleased about this, but you camaro guys have some awesome chassis options out there.
With the orange 66 chevelle the RS concerts has is a neat car. I do not like any wheel over 18" on a chevelle.. It does not to me look any good. I would like a 18X12 wheel in the rear and a 18X9 in the front. Cornering is not the biggest factor but I want something with 700-850hp and need a stable chassis and rear tire to handle the power on the street.
Thanks for all the input. This decission helps. My project is now a complete redo. Not going to cut coners this time, Had the velle for 22 years now and I want to do the build like I have always wanted.
Blessings,
Old 09-24-2007, 08:18 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Blessings,
It takes more then a chassis to fit a 12" wheel, you'll also have to mini tub it.
Old 09-28-2007, 06:09 PM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
Hi everyone. Quick intro. My name is Phil and I am one of the owners of the Roadster Shop (RS Performance) and was the one driving the orange Chevelle at Run to The Hillls. I am new to the message boards so bear with me a little.
There are definitely more advantages to our chassis than just strength. Bolt on componets are just that...bolt on. Not to be putting anyone down, but when using an original frame as a starting point there are a good number of limitations that come into play. We are a chassis manufacturer for over 20 years and have always found that if you are looking for a change from stock, the best thing to do is start from scratch and design around the desired outcome rather than work around what is there, and settle for the outcome.
That in mind, we saw that the Chevelle frame and suspension left many things to be desired... performance handling, sloppy steering, body roll, strength, rigidity, accomodating a decent size wheel and tire, lowered ride height and many more.
To check out all of the specifics of the chassis please click on the link below.
http://www.roadstershop.com/rsperformance.htm
If anyone out there is interested in the chassis, I invite you to come talk with us at one of the shows. I would be more than happy to take you for a ride in the car, or around the autocross track (if available). A ride in that car is hands down better than any sales pitch or bench racing over specs!
Upcoming Shows:
Good Guys Ft. Worth, TX 10/5 - 10/7 Autocross event
Good Guys Pleasanton, CA 11/10 - 11/11
Good Guys Scottsdale, AZ 11/16 - 11/18
Old 09-29-2007, 07:02 AM
i like it im with the rest of them stick with the stock frame and build it up. been me id go for art morrison or schwartzperformance.com
Old 09-29-2007, 09:27 AM
TravisB TravisB is offline
Welcome Phil,
Glad you found the site and joined in to the conversation. I have seen the yellow car several times it is a bad ass ride for sure. We have 2 roadster shop frames in the shop right now one for a 57 nomad, one for a 55 pickup. I can tell everyone first hand these frames are hands down the nicest frames out there for tri fives short of having something custom built maybe. I have seen the Chevelle frame and looked over pretty close it has several advantages over a stock frame. You can build up a stock chassis all you want but you still arent going to be able turn worth a dam with a 275 front or stick anything over a 10" wide tire under the rear without major surgery. Trust me I know I would be happy to take pics for anyone because I have a chevelle frame that I cut the hell out of and decided to stop and go with a aftermarket chassis. The one thing the RS frame offers that Art Morrison can not.........is the RS frame bolts in. Buy it bolt it in finsh body work and go on.
I hope you guys sell the **** out of them Phil
Kenny Davis Hot Rods
Old 09-29-2007, 09:42 AM
PTAddict PTAddict is offline
Originally Posted by Derek69SS
The big rear tires are cool if you're not serious about road-racing/track days (which most of us aren't but if you are...), they will come up to temp much slower than the smaller fronts, effecting the balance of the car differently throughout the run... if it starts neutral, when the fronts get sticky it will go loose, then the fronts get too hot as the rears just start to get sticky and it goes tight. They also require running the springs/shocks further inboard negatively effecting the motion-ratios.
FWIW, my '71 Camaro with a modified LS1 uses 265 front and 295 rear Pilot Sport Cup tires on the track (Portland Raceway). After a 20 min session, the pyrometer shows the rear tires 5-10 degrees hotter than the fronts, even with 4 PSI greater hot pressure.
I notice that high-powered RWD cars with near 50/50 weight balance (Viper, Z06) are often running 50mm or more rear stagger, even in full-race setups. You want that kind of car to keep the rear end stuck down when hard on the throttle exiting turns. Something like, say, a spec Miata is a somewhat different story ...
Finally, keep in mind that a solid axle car provides no provision for negative camber in the rear. Personally, I will run the biggest tires that will fit on both ends, then tune with camber, shocks, and tire pressures.
Old 09-30-2007, 04:02 PM
sinned's Avatar
sinned sinned is offline
My 68 "A" body ran 275/17's up front and 11.5" rears. I had one of the tightest turning radius' of any "A" body ever built (thanks to custom uprights and speedway steering arms).
Dennis
Old 09-30-2007, 09:50 PM
there are exceptions to every rule.... . I havent seen you on here in awhile dennis how are ya?
Old 10-01-2007, 06:51 AM
sinned's Avatar
Still hanging in there.
Dennis
