Old 12-02-2008, 04:30 AM
Originally Posted by ProdigyCustoms View Post
No, The width of the rear really has nothing to do with how much tire you can get in there. you can only shove so much in the wheel well. The width of the rear really only changes how much lip you get on the wheel.
Just for example, say you need a 6" backspace on a stock width rear, and you end up with a 3" lip on a 10" wheels. If you narrow the rear 1 inch PER SIDE, you could reduce the backspace 1" and pick up 1" of outer lip for a 4" lip.
Or, say you mini tub and do not narrow the rear, you need a 8" back space and have a 3" outer lip. But if you narrow the rear 4 inches you can do a 6" backspace and get a deeper 5" outer lip
Great info thanks Frank.
Old 12-02-2008, 10:36 PM
goob8869 goob8869 is offline
Originally Posted by EVS Motors Inc. View Post
From my experience you can fit a 10" wide wheel in the back. A 275mm tire is the safest wide tire to run, but you can also fit a 285 with some fender rolling and trimming.
Do you have any pictures with a 67 or 68 with this size on them
Old 12-02-2008, 11:38 PM
skatinjay27's Avatar
curtis's 67 had 10" with 285 on his...
dont know the exact BS but tony watley would since he's the one that ordered them. they have pretty big lips for 10"s though.
http://www.fquick.com/garages/viewga...=1&carid=11351
AJ
Old 12-03-2008, 09:55 PM
do you know how I can get in touch with him
Old 12-04-2008, 02:34 AM
pm him. thier board names here are
curtis- spiffav8
tony-nineball
AJ
Old 11-17-2012, 06:25 PM
Surfman423 Surfman423 is offline
Is the general concensus a 20x10 with a 275 will fit athe rear of a 67-68 Camaro? Are you relocating springs to accomplish thus?
Old 11-18-2012, 05:52 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
It'll fit on a stocker, but it won't be able to sit low. No way that will tuck under the wheel house. Just depends on what's more important to you.
Old 11-18-2012, 07:18 AM
My plan is to drop it 2" with a Hotchkis TVS kit. Would a 20x8.5 be better or should I just stick with 18" all around?
Old 11-18-2012, 08:48 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
18" all around is the way to go. 20" is way to big and ends up goofy looking IMHO.
Curtis
Old 11-18-2012, 08:57 AM
Flash68's Avatar
Flash68 Flash68 is offline
Doctor Fresh will be unfriending you on facebook in... 3... 2... 1...
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
