Old 05-08-2009, 01:34 PM
GrabberGT's Avatar
GrabberGT GrabberGT is offline
Originally Posted by Steve1968LS2 View Post
We just did this to the front. We did them in sets of two for the rotor to the hat.
I think how many are joined is pretty unimportant so long as it's done correctly. If I had five bolts I would agree that all together would be the easiest.
You post this AFTER I already wire all 10 bolts together. Where was this thread last week? LOL Now I know. 3 more rotors to do.
Chris
Its not a Vega!!!!
Total Cost Involved - Total Control Products - Gateway Performance - Fatman - MaverickMan Carbon
Old 05-08-2009, 01:52 PM
Bryce Bryce is offline
here is a pic of my saftey wire on the wilwood brakes, I did the 2,3 combo.
I hope this helps. To get a better view you might save it to your computer and zoom in.
Old 05-08-2009, 03:32 PM
Josh69 Josh69 is offline
I did the 2 and 3 also on the hub....and just did pairs of two for the rotor/hat. When I ran the wire, I made sure that if one bolt was going to loosen, that it was oriented to pull the other bolt tight...so they would cancel each other out. Honestly I don't know if that works, but that's how I strung them together.
The pliers was an interesting learning curve....took two of us about a half an hour to figure it out...and I used to think we were the smart ones!
1969 Firebird, Black w/Parchment Arizen interior, 383 Pontiac Stroker (350/428 crank), TKO600, Moser 12 bolt, 18" TTII's, Hotchkis, GW, DSE, Speed Tech, Vintage A/C, etc.
Old 05-08-2009, 03:43 PM
yes, the idea of saftey wiring bolts together is if one loosens if would have to tighten the other and vis-a-versa.
