Old 05-06-2009, 05:31 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Question about safety wire and Wilwood Brakes
I'm in the middle of installing my Wilwood 12.2" brakes. I've run safety wire on all the bolts connecting the adapter plate to the rotor. Now I need to run safety wire on all the bolts attaching the hubs to the adapter plate/rotor. My question though is regarding the fact that there are only 5 bolts holding the hub on. Am I supposed to run safety wire to only 4 of them or do I need to double some of them up and connect each bolt to the one beside it? Any pics would be great. Thanks in advance.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
New Gen Splitters
LS3 and TKO600
Old 05-06-2009, 06:39 PM
ironworks's Avatar
Wire 3 togther and then 2 togther. You could do all 5 togther if you wanted or needed.
Old 05-06-2009, 07:42 PM
Yup, I run it continuous
Frank Serafine
Old 05-06-2009, 08:31 PM
scherp69's Avatar
Thanks guys. Frank, do you do the rotor and adapter plate continuous also, or just the five on the hub.
Mike
New Gen Splitters
LS3 and TKO600
Old 05-06-2009, 08:36 PM
Steve1968LS2's Avatar
We just did this to the front. We did them in sets of two for the rotor to the hat.
I think how many are joined is pretty unimportant so long as it's done correctly. If I had five bolts I would agree that all together would be the easiest.
There will be a story on this in the July Camaro Performers.. performed by none other than David Pozzi.
Old 05-06-2009, 09:52 PM
scherp69's Avatar
Thanks Steve. I think that's how I'm going to end up doing mine. I think half the battle is just learning how to use the pliers. Do any of you have any pics you could post, just to make sure that I have done it right. Thanks again for the responses.
Mike
New Gen Splitters
LS3 and TKO600
Old 05-06-2009, 11:39 PM
I have search this wery same info long time. This is something i have never seen in a magazine tech story ( editors take a note )
63 Z06
Old 05-07-2009, 06:31 AM
Steve was in town last week and we were out to dinner. he told me about his article. I am going to see if after it is released, if I can include a copy of the article with our Total Car Packages. I think it would be a nice addition to the pliers and wire we supply in the kit.
Frank Serafine
Old 05-07-2009, 06:55 AM
Already written and turned in. lol
We were doing it and I though "hey, I don't remember ever seeing a story on this" So I grabbed my camera. Sure beats doing another cam-swap story.
The process is like tying shoes. If you've never done it then it seems coplicated but it's really pretty easy.
I remember the first time I ever held a pair of the special pliars.. I was like "ok, what the hell do I do with these??"
Old 05-07-2009, 07:55 AM
I agree 110% !!! Let me know Steve wich issue you run it , and i try to get my hands on it
Even better !! I am going to need the wire and pliers as well !!!
63 Z06
