Old 08-01-2010, 09:44 AM
Ron in SoCal's Avatar
There's a comment I hadn't heard before...why does safety dictate removal of the DBW? I was planning on using it.
Ron in SoCal
69 Camaro in progress
Old 08-01-2010, 10:01 AM
The drive by wire is of zero concern is a factory ECM is used. 99% of the LS motors we sell and install use a factory / GMPP ECM.
As Pantera mentions, I too have concerns with aftermarket ECMs and DBW even though some aftermarket systems do have DBW capabilities.
Frank Serafine
Old 08-01-2010, 10:28 AM
Thanks Frank. One of these day you should write a book...
Ron in SoCal
Old 08-01-2010, 12:10 PM
Pantera EFI Pantera EFI is offline
Default DBW=Drive To Death
At the OEM level, I know about 9,000,000 reasons why it was a BAD idea !
Lance
Old 08-01-2010, 07:43 PM
Good info Lance!
Old 08-01-2010, 07:44 PM
Lance
Lance - please exlpain that one. I'm sure you have experience, so please share?
Ron in SoCal
Old 08-10-2010, 08:33 AM
Rhino Rhino is offline
Originally Posted by wiedemab View Post
I could be wrong, but isn't the L92 VVT and the LS3 not.
I always thought LS3 + VVT = L99? What's the difference between the two?
Old 08-10-2010, 11:01 AM
XcYZ's Avatar
XcYZ XcYZ is offline
DBW is the way to go.
How long have the OEM's been using DBW?
Other than Toyota trying to kill their customers, it's been good.
My LS7 69 Camaro
Old 08-10-2010, 12:33 PM
DBW has been treating me good so far in my DD. I will say that tuning it isn't as hard as I expected. It's nice not having to worry about the Idle air circuits, plus the PCM can easily modulate throttle so it can compensate for many drive-ability issues you see with a cable operated TB. You tell it desired air flow and it does the rest.
From an aesthetic standpoint; It also looks much nicer sitting in the engine bay.
The only issue I've ever had is a wiring issue caused my truck to go into limp home mode. It essentially sets the throttle at about 1500 regardless of pedal input. It's a little bit of an inconvenience, but a necessary evil. At least it lets you drive it back home.
If I didn't already have my PCM and harness I'd easily switch to DBW.
