Old 07-18-2010, 07:47 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
What degree ends are you using?
I've found using the Taylor 135* ends usually work best.
If all else fails, and your ends are directly on the header tube, take some header gasket, cut it into small pieces, and wedge it between the plug end and the tube. The more you can get in there the better.
Old 07-18-2010, 06:30 PM
I can't believe a guy with as beautiful of a car as you have just wrote that!
Old 07-19-2010, 08:14 AM
MarkM66's Avatar
My plug wires don't hit my headers.
I guess I should of just told him to get a set of $2000 Lemons headers. Money may be no object to you Greg, but it is to some.
I guess my suggestion is so "rigged" huh? So some small almost non visible pieces of insulation is so much worse then some big insulating boots? Gotcha.
Don't you have some cool ball milled valve covers or Torque Thrust wheels to polish?
Old 07-19-2010, 07:31 PM
67ragtp 67ragtp is offline
Here's some insulating boots I use, they aint the best looking pieces, but they work - Rich
