Old 11-11-2010, 01:42 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Originally Posted by JND View Post
You would be correct, range is 11.5-12.0-12.5. so looks like 12 is the sweet spot. i guess i still need to move the frame rails in 3" since the tires are 13.3 wide.
Do you have a rear sway bar?
I never put a sway bar on it. I don't have it anymore, and didn't drive it enough to know if it needed one or not.
Old 11-27-2010, 08:57 PM
okyankee okyankee is offline
Originally Posted by MarkM66 View Post
I narrowed the frame on my '66 the same way. But I moved mine in 3" per side instead of 2" like Malitude. Which fit a 20x12 with a 335/30
i want to do the same on my 65 chevelle. is this the stock width rear end just with wheels with correct backspacing? thanks for any help.
Old 11-27-2010, 09:14 PM
camcojb camcojb is offline
On Malitude it was a narrowed rear end, and I'd guess Mark did the same. If you minitub but keep the rear end stock width you end up with wheels with no depth to them. In other words, they'll have to have a lot of backspacing to be wide and still fit. If you narrow the rear you can get a more centered wheel offset which I think looks much better.
Old 11-27-2010, 09:16 PM
then that calls for some rear end chopping. thanks for the help.
Old 11-27-2010, 09:28 PM
btw, do you know how much per side to narrow the rear end?
Old 11-27-2010, 09:36 PM
that would depend on wheel width and offset as well as tire size. Best thing to do is complete the frame and tub mods, get the wheel/tire combo, set them in place and measure for the rear width.
Old 11-27-2010, 09:38 PM
thanks. i know the wheels will be 20x12 for sure. that is as far as i got. thanks for the info.
Old 12-03-2010, 01:25 PM
BANKO's Avatar
BANKO BANKO is offline
Default Thanks for the good info and pics
Great info, I love the pics.
Did either of you guys do this on a frame table?
@Mark, looks like you used boxed frame rails behind the rear axle body mounts. Is this 2"x4"?
Thanks, Josh
Old 12-03-2010, 05:47 PM
MarkM66's Avatar
Thanks, Josh
No, just welded in some braces before cutting, and measured before welding.
That's just the factory frame in the back that I boxed.
Old 01-01-2011, 07:45 PM
tim65chevelle tim65chevelle is offline
Default ben there doing that
I'm working on a 65 chevelle , 64&65 have very small provisions for tires (The frames are the same 64-67)1966&7 have a lot bigger wheel well.I took 2" out of each side of my frame( I notched it) replaced it with a 3/8 plate.You cant take out any more than 2" (upper spring perches are right there) I also had to move 2nd to last body mount.By notching frame instead of moving it. I was able to keep stock gas tank factory upper and lower bars.(no frame jig required. My wheel opening measure out to 13 3/4"now. 66-67 cars are wider so it would measure out more. I have a lot of pics . they are to big to send?(I'll try to make them smaller)Or maybe I could send them direct to your e-mail.(I'm not very computer savy)TIM I'm doing min tubs right now.(419)371-4955
Last edited by tim65chevelle; 01-03-2011 at 10:03 AM. Reason: trying to work on attachments (no opition to try again)
