Old 11-19-2010, 04:57 PM
Ron in SoCal's Avatar
Originally Posted by akrapovic View Post
my understanding is that the inconel is used in blower application on the exh side due to it ability to handle increased heat. Pretty common actually. please keep in mind that I'm no engine builder. I'll ask the guys at motor city speed. when it was explained to me by billy he mentioned several motors that he built that were similar to mine when he was building motors for wheel to wheel. also apparently the formula 1 cars use them bc their ability to handle extreme temps.
Everthing you said is correct. Inconnel works better for extreme duty like blowers and boats. Blowers due to heat, and boats due to higher RPM/always on...
Ron in SoCal
69 Camaro in progress
Old 11-19-2010, 05:18 PM
KPC67's Avatar
KPC67 KPC67 is offline
[QUOTE=akrapovic;317406]Here are the piston squirters. Side note, if anybody is looking for these for an LS7 or RHS block I have an extra set.
[/QUOTE
How much do you want for the squirters?
Kevin Carter
Old 11-19-2010, 05:32 PM
akrapovic's Avatar
akrapovic akrapovic is offline
pm sent
Old 11-19-2010, 05:38 PM
JamesJ JamesJ is offline
I am using inconnel exh as well on my blower motor...
James J.
Old 11-19-2010, 08:29 PM
67ragtp 67ragtp is offline
Does all the factory LS7 blocks have the provisions to install those squirters? Or is special machining required?
Thanks Rich
Old 11-19-2010, 08:32 PM
akrapovic's Avatar
Special machining is required. It wasnt a big deal for mine. Tap threaded hole into oil passage and also provision for locating pin.
Old 11-20-2010, 01:09 PM
speedshftr speedshftr is offline
i never drove a ls7 but had a few ls6 cars and they were really nice engines.im jellous cause my new camaro build is just a small block to start off.money issues was the culprit on that one.your engine is gonna be sweet.
