Old 11-18-2010, 05:59 PM
akrapovic's Avatar
akrapovic akrapovic is offline
Default Ls7 coming together!
I dropped by my motor shop and my motor is coming together. Short block is being assembled just waiting on heads. Woo hoo!!!
Just saying
Old 11-18-2010, 06:09 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
Lets get some specs on that Badboy You gonna have Billy dyno it when its done?
Autokraft
Old 11-18-2010, 09:56 PM
akrapovic's Avatar
It's a procharged motor wet sump motor. I'm going to run a D1SC with the helical gear set. Mild cam so it's hopefully somewhat of a sleeper when it's idling. Wiseco pistons, K1 rods, ls7 heads with upgraded valves/springs. Fast 102 intake. Goals for boost are about 15lbs, we'll see depending on how much the motor makes on the dyno NA. Goal is 900hp hopefully a bit more. Taking a page from the ls9 and going with piston squirters. The car is a 69 camaro with a T56 from D&D.
Old 11-18-2010, 10:01 PM
KPC67's Avatar
KPC67 KPC67 is offline
What kind of valves and springs are you using?
Kevin Carter
Old 11-18-2010, 10:08 PM
akrapovic's Avatar
Stainless int and inconnel exh. Stock sizes. I'll be running PAC springs.
Old 11-19-2010, 05:55 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Motor porn.
My LS7 69 Camaro
Old 11-19-2010, 08:53 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Very nice indeed. That is going to be one beast of an engine. I bet you hit that goal of 900 HP.
Good luck and keep us posted!
Old 11-19-2010, 01:04 PM
akrapovic's Avatar
Here are the piston squirters. Side note, if anybody is looking for these for an LS7 or RHS block I have an extra set.
Old 11-19-2010, 01:07 PM
akrapovic's Avatar
Yes they will be doing the break in on the engine dyno. Hopefully Mid December!
Old 11-19-2010, 02:45 PM
akrapovic's Avatar
my understanding is that the inconel is used in blower application on the exh side due to it ability to handle increased heat. Pretty common actually. please keep in mind that I'm no engine builder. I'll ask the guys at motor city speed. when it was explained to me by billy he mentioned several motors that he built that were similar to mine when he was building motors for wheel to wheel. also apparently the formula 1 cars use them bc their ability to handle extreme temps.
