Old 03-23-2011, 05:12 AM
Rybar's Avatar
Rybar Rybar is offline
Originally Posted by XcYZ View Post
Sounds like you might have air trapped in the system.
With that identical radiator and fan setup, I see 180* ~ 190* with a 180* thermostat. I have very little fluctuation, even when stuck in stop and go traffic in the heat of summer.
Mine runs similar to Scotts, and I would guess air trapped in the system or replace the t-stat. Running a GM t-stat
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 03-23-2011, 09:45 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
i always use this to fill my systems
http://www.summitracing.com/parts/LIL-24610
i also have a cooling system vacuum. it pulls a vacuum on the whole system and when then you stick the hose in new coolant and turn the valve and it fills the system. it works pretty good but i like the funnel better.
