Old 03-22-2011, 12:38 AM
Tom.A's Avatar
Tom.A Tom.A is offline
Default Those with LS conversions: What kind a of coolant temperature are you seeing?
As the title says would like to know what you guys are seeing. I ventured out for a little spin around the block and noticed the temp hit 220ish. I pulled over and shut it down. The fans had just kicked on around 210F I think.
I did want to let it run more to see if it came down. Looking at the vette forums this sounds normal but it seemed high to me. If this is normal what is high?
For the record I am running a LS3 with Ron Davis LS radiator with dual spal fans. I guess I need to see what John @ Speartech configures the ECU.
I also have no idea what thermostat I have.
Thanks,
Tom
Old 03-22-2011, 05:06 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Sounds like you might have air trapped in the system.
With that identical radiator and fan setup, I see 180* ~ 190* with a 180* thermostat. I have very little fluctuation, even when stuck in stop and go traffic in the heat of summer.
My LS7 69 Camaro
Old 03-22-2011, 07:49 AM
dhutton dhutton is offline
How did you connect the steam vent? I also remember it took a bit of effort to burp the system the first time I filled it. I disconnected the upper hose from the radiator if I remember right.
Don
Old 03-22-2011, 08:45 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
if its a stock stat and the ECM hasn't been tuned to turn the fans on sooner then your right about where it should run at 220*. now if its a 180* stat and the fans are tuned to turn on sooner then you may have an air pocket in the system.
Old 03-22-2011, 09:13 AM
hifi875's Avatar
hifi875 hifi875 is offline
i am running the dual spal fan controller w/a prc radiator and factory 187degree stat. mine won't get to 200 at all. stays between 180-195
Old 03-22-2011, 10:31 AM
Jr's Avatar
Jr Jr is offline
I used fans from a 2000 Camaro. My temp never goes over 198.
Old 03-22-2011, 08:07 PM
Z06vette's Avatar
Z06vette Z06vette is offline
As mentioned above, it doesnt matter what stat you are running if the fans arent turning on until 220, which is about right for stock ecu setting. I too had trouble with air trapped in the system. If the upper & lower hoses are hot when running engine, air is likely not the problem; at least that has been my experience. With a 187 stat you could maybe set the ecu to turn the fans on at 200 & off at 190. Any lower & the fan will likely just run all the time. Let us know what you find out.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 03-22-2011, 10:02 PM
69x22's Avatar
69x22 69x22 is offline
Mine is 195 to 200 degrees, I tied the steam vent into the top of the water pump where the upper hose comes off the water pump.
Old 03-22-2011, 10:47 PM
Tom.A's Avatar
Thanks for the replys and help. It looks like it was an air pocket. I changed the t-stat also since I pulled the hose. I also called John @ Speartech and he said unless otherwise asked he sets the fans to come on @ 205F. Also in case somebody finds this thread I think it would be better to fill the upper rad-hose before hooking it up. I did not do that the first time which is likely how I got an air pocket. Took it for a spin and it ran around 195 range. The fans never came on with 15 mins. of driving/running. So thanks again this problem solved On to the next problems of leaking oil, shreding serp belts and no working power steering
Tom
Old 03-22-2011, 11:47 PM
69x22's Avatar
I had to fill the engine with coolant by taking the upper hose off of the radiator.
