Old 09-14-2012, 10:48 AM
Rybar's Avatar
Rybar Rybar is offline
I ordered one yesterday. Everyone with an EFI Tank from Ricks or DSE should have one of these mandatory if what it says it does works.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 09-15-2012, 11:41 AM
westoz westoz is offline
I even bought one as a diff breather . Can't say just how good this bit of kits is. Thanks Jp
Lyndsay
___________________
69 RS / SS Camaro - LS6 & T56
Old 11-25-2012, 06:00 PM
blazer1970 blazer1970 is offline
May have to pick one of these up to go with my new narrowed Rick's tank.
Old 11-25-2012, 07:00 PM
randy randy is offline
what about a group buy?
Old 12-01-2012, 05:05 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
I'm in!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 12-01-2012, 06:25 PM
Boss 5.0's Avatar
Boss 5.0 Boss 5.0 is offline
Originally Posted by 214Chevelle View Post
I'm in!
Me too!!
I have another question for some of you. I have a drop in Mustang EFI tank in my car. I am just getting ready to start looking into plumbing. While the tank and fittings are in the trunk, I plan to run the send/return lines along the frame and the vent up to the II much vent.
My question is, when I run those three hoses from the tank through the floor, should I just drill holes and use grommets, or does someone know of through the floor fittings I can use for fuel? I have never heard of anything like that, but would prefer to go that route.
Glenn
Copper Hill Rod & Custom
1955 Chevy BelAir
1951 Chevy 3100
1987 Chevy R10
Glenn
Old 12-01-2012, 06:45 PM
colin204 colin204 is offline
Count me in for a group buy
Check out my current build https://lateral-g.net/forums/show...512#post270512
Old 02-02-2013, 06:18 PM
DRJDVM's '69's Avatar
What size line are you guys running?
My Ricks tank has two vent ports....when I talked to them about "why 2?"....they recommended I run both separately....with the Aeromotive pump they told me it will tend to create a vaccum in the tank if I only run one...
Seems like a PITA to have to run 2.....
I'm using a Ridetech fuel neck...which has a vent in the neck if I want to use that too...
Old 02-02-2013, 06:47 PM
parsonsj parsonsj is offline
A single 3/8" line is more than adequate to vent any tank up to about 2000 hp.
Air is replacing gasoline, and flows at approximately 25 gallons per minute through a 1/4" tube at atmospheric pressure. I've yet to see any fuel pump not on a Top Fuel dragster empty one of our fuel tanks in 40 seconds.
Hope that helps.
John Parsons
Old 02-03-2013, 10:08 AM
With those figures do you think a 1/4 inch line would be enough?
I'm running a vent off my diff too and figured 6 AN is overkill... So hoping running the same size lines will make it easier when buying hose and fittings
